1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Questions about devIocStats on vxWorks
To: Mark Rivers <[email protected]>, "'Andrew Johnson'" <[email protected]>
Date: Tue, 7 Jun 2016 23:43:02 +0000
Hi Mark,
> I see that there are 2 cpuUsageTask tasks.  This is true on all of my VxWorks IOCs.  Is this
> normal?
No, it is not normal.  It is possible that you loaded the devIocStats database twice with different names.  devIocStats is far from perfect - one of its imperfections is that it doesn't check if initialization is already done and goes ahead and does it again.   Need a bug report for this.
Stephanie
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Friday, June 03, 2016 10:17 AM
> To: 'Andrew Johnson'; Allison, Stephanie
> Cc: [email protected]
> Subject: Questions about devIocStats on vxWorks
> Hi,
> I am running devIocStats (current master branch from github) on VxWorks 6.9.4.1.
> I ran into some issues on this IOC yesterday where it would not accept any new channel access
> connections.  That normally indicates either CPU saturation or memory low.  The memory was fine
> (more than 300 MB free).  I could not look at the devIocStats medm screens because it was not
> accepting any new CA connections and I did not happen to have that screen open.
> However, I was able to use spy and got the following output:
>     NAME         ENTRY       TID      PRI   total % (ticks)  delta % (ticks)
> tJobTask     0x1c6b00     0x23b8fa0     0     0% (       0)    0% (       0)
> tExcTask     0x1c61f8     0x33a5d0      0     0% (       0)    0% (       0)
> tLogTask     logTask      0x23bc340     0     0% (       0)    0% (       0)
> tShell0      shellTask    0x7aae3e0     1     0% (       0)    0% (       0)
> tWdbTask     0x261f48     0x26e0a30     3     0% (       0)    0% (       0)
> tSpyTask     spyComTask   0x7e94080     5     3% (     147)    3% (      72)
> ipcom_tickd  0x285b88     0x26c6ea0    20     0% (       0)    0% (       0)
> tVxdbgTask   0x13185c     0x26da910    25     0% (       0)    0% (       0)
> tNet0        ipcomNetTask 0x23c1060    50     2% (     102)    1% (      40)
> ipcom_syslog 0x16bf48     0x268d220    50     0% (       0)    0% (       0)
> tNetConf     0x1b74b8     0x26b9a50    50     0% (       0)    0% (       0)
> ipcom_telnet ipcom_telnet 0x26cdcc0    50     0% (       0)    0% (       0)
> ipsntps      0x1ba330     0x26d1450    50     0% (       0)    0% (       0)
> tPortmapd    portmapd     0x26d5570    54     0% (       0)    0% (       0)
> NTPTimeSync  0x352d878    0x278c540   109     0% (       0)    0% (       0)
> ClockTimeSyn 0x352d878    0x278f770   109     0% (       0)    0% (       0)
> ipUnidig     0x352d878    0x3bc2b50   109     0% (       0)    0% (       0)
> Ip330intTask 0x352d878    0x3c05c20   109     0% (       0)    0% (       0)
> abDone00     0x321181c    0x4b203a0   122     0% (       0)    0% (       0)
> abScan00     0x3211d8c    0x4b1d940   123     0% (       0)    0% (       0)
> cbHigh       0x352d878    0x4b061e0   128     0% (       0)    0% (       0)
> timerQueue   0x352d878    0x4ae4bd0   129     0% (       0)    0% (       0)
> scanOnce     0x352d878    0x6a249b0   129     1% (      56)    0% (      20)
> IK320Logger  0x3247cdc    0x4b0e7b0   130     0% (       0)    0% (       0)
> scan0.1      0x352d878    0x6d08140   133     0% (       7)    0% (       1)
> scan0.2      0x352d878    0x6d01610   134     1% (      46)    0% (      10)
> cbMedium     0x352d878    0x4afd9a0   135     0% (      21)    0% (      18)
> scan0.5      0x352d878    0x6cfaae0   135     0% (       7)    0% (       2)
> drvQuadEMCal 0x352d878    0x3ed9630   136     0% (       0)    0% (       0)
> scan1        0x352d878    0x6cf3fb0   136     0% (       0)    0% (       0)
> CAS-client   0x352d878    0x7abaf40   136     0% (       0)    0% (       0)
> scan2        0x352d878    0x6ced480   137     0% (       0)    0% (       0)
> scan5        0x352d878    0x6ce6950   138     0% (       5)    0% (       2)
> timerQueue   0x352d878    0x39fa1e0   139     0% (       0)    0% (       0)
> timerQueue   0x352d878    0x3bb7240   139     0% (       0)    0% (       0)
> scan10       0x352d878    0x6cdfe20   139     0% (       1)    0% (       1)
> cbLow        0x352d878    0x4af5160   140     3% (     179)    4% (      89)
> timerQueue   0x352d878    0x4b24ee0   141     0% (       0)    0% (       0)
> CAC-UDP      0x352d878    0x6f8afe0   147     0% (       1)    0% (       0)
> CAC-UDP      0x352d878    0x7135d20   147     0% (       1)    0% (       0)
> timerQueue   0x352d878    0x6f76370   148     0% (       8)    0% (       2)
> CAC-TCP-send 0x352d878    0x6fcfcd0   148     0% (       0)    0% (       0)
> CAC-event    0x352d878    0x70844b0   148     2% (     116)    2% (      47)
> CAC-TCP-send 0x352d878    0x7093aa0   148     0% (       0)    0% (       0)
> CAC-TCP-send 0x352d878    0x70a3100   148     0% (       0)    0% (       0)
> CAC-TCP-send 0x352d878    0x70b2760   148     0% (       0)    0% (       0)
> CAC-TCP-send 0x352d878    0x70c1dc0   148     0% (       0)    0% (       0)
> CAC-event    0x352d878    0x7119160   148     0% (       0)    0% (       0)
> timerQueue   0x352d878    0x7121660   148     0% (      16)    0% (       6)
> CAC-event    0x352d878    0x26f7e20   148     0% (       0)    0% (       0)
> serial1      0x352d878    0x3c21b40   149     0% (       0)    0% (       0)
> serial2      0x352d878    0x3c2d260   149     0% (       0)    0% (       0)
> serial3      0x352d878    0x3c326a0   149     0% (       0)    0% (       0)
> serial4      0x352d878    0x3c3b940   149     0% (       0)    0% (       0)
> serial5      0x352d878    0x3c466e0   149     0% (       0)    0% (       0)
> serial6      0x352d878    0x3c4f060   149     0% (       0)    0% (       0)
> serial7      0x352d878    0x3c57e30   149     0% (       4)    0% (       0)
> serial8      0x352d878    0x3c62c20   149     0% (      10)    0% (       3)
> serial9      0x352d878    0x3c73690   149     0% (       0)    0% (       0)
> serial10     0x352d878    0x3c83ba0   149     0% (       0)    0% (       0)
> serial11     0x352d878    0x3cb2900   149     0% (       0)    0% (       0)
> serial12     0x352d878    0x3cbb0e0   149     0% (      23)    0% (       6)
> serial13     0x352d878    0x3ccd400   149     0% (       0)    0% (       0)
> serial14     0x352d878    0x3ce0370   149     0% (       0)    0% (       0)
> serial15     0x352d878    0x3d0ed90   149     0% (       0)    0% (       0)
> serial16     0x352d878    0x3d16fc0   149     0% (       0)    0% (       0)
> serial17     0x352d878    0x3d202f0   149     0% (       0)    0% (       0)
> serial18     0x352d878    0x3d49bd0   149     0% (       0)    0% (       0)
> serial19     0x352d878    0x3d73010   149     0% (       0)    0% (       0)
> serial20     0x352d878    0x3d796b0   149     0% (       0)    0% (       0)
> serial21     0x352d878    0x3d7fd50   149     0% (       0)    0% (       0)
> serial22     0x352d878    0x3d863f0   149     0% (       0)    0% (       0)
> serial23     0x352d878    0x3d8ca90   149     0% (       0)    0% (       0)
> serial24     0x352d878    0x3d93130   149     0% (       0)    0% (       0)
> IP_QE1       0x352d878    0x3da0750   149     0% (       0)    0% (       0)
> QE1          0x352d878    0x3daa930   149     0% (       0)    0% (       0)
> drvTetrAMMTa 0x352d878    0x3edffb0   149    13% (     611)   13% (     265)
> QE1_STATS1_P 0x352d878    0x3f00700   149     0% (       0)    0% (       0)
> QE1_STATS2_P 0x352d878    0x3f3b7c0   149     0% (       0)    0% (       0)
> QE1_STATS3_P 0x352d878    0x3f73510   149     0% (       0)    0% (       0)
> QE1_STATS4_P 0x352d878    0x3faa780   149     0% (       0)    0% (       0)
> QE1_STATS5_P 0x352d878    0x3fe1a20   149     0% (       0)    0% (       0)
> QE1_STATS6_P 0x352d878    0x40189a0   149     0% (       0)    0% (       0)
> QE1_STATS7_P 0x352d878    0x404fac0   149     0% (       0)    0% (       0)
> QE1_STATS8_P 0x352d878    0x4086bb0   149     0% (       0)    0% (       0)
> QE1_STATS9_P 0x352d878    0x40bdb90   149     0% (       0)    0% (       0)
> QE1_STATS10_ 0x352d878    0x40f4b70   149     0% (       0)    0% (       0)
> QE1_STATS11_ 0x352d878    0x412c190   149     0% (       0)    0% (       0)
> QE1_FileNetC 0x352d878    0x4162290   149     0% (       0)    0% (       0)
> QE1_FileNetC 0x352d878    0x416ad20   149     0% (       0)    0% (       0)
> QE1_Image1_P 0x352d878    0x418b300   149     0% (       0)    0% (       0)
> QE1_TS1_Plug 0x352d878    0x41bfb40   149     0% (       0)    0% (       0)
> QE1_FFT1_Plu 0x352d878    0x426b9e0   149     0% (       0)    0% (       0)
> QE1_FFT2_Plu 0x352d878    0x4289080   149     0% (       0)    0% (       0)
> QE1_FFT3_Plu 0x352d878    0x42a6320   149     0% (       0)    0% (       0)
> QE1_FFT4_Plu 0x352d878    0x42c3520   149     0% (       0)    0% (       0)
> QE1_FFT5_Plu 0x352d878    0x42e07f0   149     0% (       0)    0% (       0)
> QE1_FFT6_Plu 0x352d878    0x42fdf00   149     0% (       0)    0% (       0)
> QE1_FFT7_Plu 0x352d878    0x431b070   149     0% (       0)    0% (       0)
> QE1_FFT8_Plu 0x352d878    0x4338610   149     0% (       0)    0% (       0)
> QE1_FFT9_Plu 0x352d878    0x43557b0   149     0% (       0)    0% (       0)
> QE1_FFT10_Pl 0x352d878    0x4372950   149     0% (       0)    0% (       0)
> QE1_FFT11_Pl 0x352d878    0x438fbe0   149     0% (       0)    0% (       0)
> IP_QE2       0x352d878    0x4394a00   149     0% (       0)    0% (       0)
> QE2          0x352d878    0x43a9cb0   149     0% (       0)    0% (       0)
> drvQuadEMCal 0x352d878    0x44dbb20   149     0% (      28)    0% (      14)
> drvAHxxxTask 0x352d878    0x44e24a0   149     1% (      73)    1% (      33)
> QE2_STATS1_P 0x352d878    0x4502700   149     0% (       7)    0% (       3)
> QE2_STATS2_P 0x352d878    0x4539800   149     0% (      10)    0% (       4)
> QE2_STATS3_P 0x352d878    0x4570900   149     0% (       8)    0% (       1)
> QE2_STATS4_P 0x352d878    0x45a7a00   149     0% (       4)    0% (       2)
> QE2_STATS5_P 0x352d878    0x45df0b0   149     0% (       7)    0% (       3)
> QE2_STATS6_P 0x352d878    0x4616030   149     0% (       9)    0% (       4)
> QE2_STATS7_P 0x352d878    0x464cfb0   149     0% (      12)    0% (       7)
> QE2_STATS8_P 0x352d878    0x4684580   149     0% (      11)    0% (       5)
> QE2_STATS9_P 0x352d878    0x46bb560   149     0% (       9)    0% (       5)
> QE2_STATS10_ 0x352d878    0x46f2540   149     0% (       7)    0% (       3)
> QE2_STATS11_ 0x352d878    0x47295b0   149     0% (       7)    0% (       4)
> QE2_FileNetC 0x352d878    0x475f5e0   149     0% (       0)    0% (       0)
> QE2_FileNetC 0x352d878    0x4768070   149     0% (       8)    0% (       2)
> QE2_Image1_P 0x352d878    0x4788bf0   149     0% (       9)    0% (       5)
> QE2_TS1_Plug 0x352d878    0x47bd430   149     0% (      11)    0% (       4)
> QE2_FFT1_Plu 0x352d878    0x48692d0   149     0% (       0)    0% (       0)
> QE2_FFT2_Plu 0x352d878    0x4886970   149     0% (       0)    0% (       0)
> QE2_FFT3_Plu 0x352d878    0x48a3b70   149     0% (       0)    0% (       0)
> QE2_FFT4_Plu 0x352d878    0x48c0d70   149     0% (       0)    0% (       0)
> QE2_FFT5_Plu 0x352d878    0x48ddf70   149     0% (       0)    0% (       0)
> QE2_FFT6_Plu 0x352d878    0x48fb0e0   149     0% (       0)    0% (       0)
> QE2_FFT7_Plu 0x352d878    0x4918250   149     0% (       0)    0% (       0)
> QE2_FFT8_Plu 0x352d878    0x4935990   149     0% (       0)    0% (       0)
> QE2_FFT9_Plu 0x352d878    0x4952b30   149     0% (       0)    0% (       0)
> QE2_FFT10_Pl 0x352d878    0x496fcd0   149     0% (       0)    0% (       0)
> QE2_FFT11_Pl 0x352d878    0x498cf60   149     0% (       0)    0% (       0)
> dbCaLink     0x352d878    0x4b0cac0   149     0% (       0)    0% (       0)
> Oms58_motor  0x352d878    0x4b14cf0   149     0% (      29)    1% (      23)
> MAXv_motor   0x352d878    0x4b1aee0   149     0% (       0)    0% (       0)
> CAC-event    0x352d878    0x6d25330   149     0% (       1)    0% (       1)
> poolPoll     0x352d878    0x6f51280   149     0% (       0)    0% (       0)
> editSseq     0x352d878    0x70e1a50   149     0% (       0)    0% (       0)
> Keithley2kDM 0x352d878    0x74aa5c0   149     0% (       0)    0% (       0)
> Keithley2kDM 0x352d878    0x74b7720   149     0% (       0)    0% (       0)
> Keithley2kDM 0x352d878    0x74bc760   149     0% (       0)    0% (       0)
> Keithley2kDM 0x352d878    0x74c1930   149     0% (       0)    0% (       0)
> motorUtil    0x352d878    0x79ecf30   149     0% (       0)    0% (       0)
> soft_motor   0x352d878    0x4b36590   150     0% (       0)    0% (       0)
> CAC-TCP-recv 0x352d878    0x6fcb7d0   150     0% (       1)    0% (       0)
> CAC-TCP-recv 0x352d878    0x708f5a0   150     0% (       0)    0% (       0)
> CAC-TCP-recv 0x352d878    0x709ec20   150     0% (       0)    0% (       0)
> CAC-TCP-recv 0x352d878    0x70ae280   150     0% (       0)    0% (       0)
> CAC-TCP-recv 0x352d878    0x70bd8e0   150     0% (       8)    0% (       0)
> CAC-UDP      0x352d878    0x7722990   153     0% (       0)    0% (       0)
> CAC-UDP      0x352d878    0x3fde2d0   154     0% (       1)    0% (       0)
> CAC-event    0x352d878    0x76af970   154     0% (       0)    0% (       0)
> timerQueue   0x352d878    0x770dd40   154     0% (       7)    0% (       4)
> CAC-TCP-send 0x352d878    0x7a005b0   154     0% (       0)    0% (       0)
> timerQueue   0x352d878    0x45a42b0   155     0% (       3)    0% (       2)
> CAC-TCP-send 0x352d878    0x4015250   155     0% (       0)    0% (       0)
> CAC-TCP-send 0x352d878    0x42dd630   155     0% (       0)    0% (       0)
> saveDataTask 0x352d878    0x7692150   155     0% (       0)    0% (       0)
> recDynInp    0x352d878    0x68775d0   156     0% (       1)    0% (       0)
> recDynOut    0x352d878    0x6880170   156     0% (       0)    0% (       0)
> CAC-TCP-recv 0x352d878    0x79fc3e0   156     0% (       0)    0% (       0)
> CAC-TCP-recv 0x352d878    0x71cd3f0   157     0% (       0)    0% (       0)
> CAC-TCP-recv 0x352d878    0x7269fc0   157     0% (       0)    0% (       0)
> CAC-UDP      0x352d878    0x75a2d30   177     0% (       0)    0% (       0)
> CAC-event    0x352d878    0x48f7f20   178     0% (      35)    0% (      15)
> timerQueue   0x352d878    0x758e120   178     0% (       2)    0% (       1)
> save_restore 0x352d878    0x7278230   179     0% (       0)    0% (       0)
> CAS-client   0x352d878    0x7307fc0   179     0% (       0)    0% (       0)
> CAS-client   0x352d878    0x7472f90   179     0% (       0)    0% (       0)
> CAS-client   0x352d878    0x7e619b0   179     0% (       0)    0% (       0)
> CAS-client   0x352d878    0x7e6d470   179     0% (       0)    0% (       0)
> CAS-event    0x352d878    0x73016e0   180     0% (       0)    0% (       0)
> CAS-event    0x352d878    0x746c6b0   180     0% (       0)    0% (       0)
> CAS-event    0x352d878    0x230bcf0   180     1% (      60)    1% (      34)
> CAS-event    0x352d878    0x7e5ae80   180     0% (       0)    0% (       0)
> CAS-event    0x352d878    0x7e66940   180     0% (       4)    0% (       3)
> CAS-TCP      0x352d878    0x6f451f0   181     0% (       0)    0% (       0)
> CAS-beacon   0x352d878    0x6f491f0   182     0% (       0)    0% (       0)
> CAS-UDP      0x352d878    0x6f4da80   183     0% (       0)    0% (       0)
> errlog       0x352d878    0x27997a0   189     0% (       0)    0% (       0)
> taskwd       0x352d878    0x279f8e0   189     0% (       0)    0% (       0)
> timerQueue   0x352d878    0x3bf2050   189     0% (       0)    0% (       0)
> ipToAsciiPro 0x352d878    0x6f71a30   189     0% (       0)    0% (       0)
> CAC-repeater 0x352d878    0x6f901d0   189     0% (       2)    0% (       1)
> cpuUsageTask 0x352d878    0x4b2a400   199    29% (    1326)   28% (     582)
> cpuUsageTask 0x352d878    0x4b2f640   199    26% (    1221)   28% (     568)
> KERNEL                                        3% (     170)    3% (      74)
> INTERRUPT                                     1% (      79)    1% (      24)
> IDLE                                          0% (       0)    0% (       0)
> TOTAL                                        86% (    4531)   86% (    2015)
> normal?
> I also see that the IDLE time is 0%, and that the cpuUsageTasks are using all of the CPU time that
> other tasks are not using.  Is this also normal?
> If it is normal, then I don't understand why the system was in a state that would not allow any new
> CA connnections.  I used the VxWorks "i" command to look at all tasks, and there were no
> suspended tasks.  checkStack showed no tasks with stack overflow.
> casr showed some things like this that look suspicious?
> TCP 164.54.160.93:51762(Ferrari): User="XAS_User", V4.13, 677 Channels, Priority=0
>       Task Id=0x7a24820, Socket FD=75
>       Secs since last send 593.58, Secs since last receive 593.58
>       Unprocessed request bytes=16, Undelivered response bytes=5192
>       State=up jumbo-send-buf
> Any ideas, and things to look at if I am able to reproduce the problem?
> Thanks,
> Mark
RE: Questions about devIocStats on vxWorks Mark Rivers
Prev: Re: epicsEventSignal() question Andrew Johnson
Next: RE: Questions about devIocStats on vxWorks Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Questions about devIocStats on vxWorks Andrew Johnson
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
