Hi Mike,
Have you worked out what those semFlush() calls are actually doing in the original code? Do they always come immediately after a semGive() for example? I think you would be best advised to try to discover what is actually going
on in the original implementation instead of just trying to mechanically convert every call; my previous discussion was partly to explain that in reality the semFlush() probably wasn't doing what the original author might have thought, and as a result you
might not need to replace it with anything. Once you've worked out how the various tasks communicate with each other you'll be in a better position to decide how to convert the signaling code.
- Andrew
Sent from my iPad
Hi Andrew,
Thanks for the explanation.
We're converting code from vxWorks to OSI (on top of RTEMS), and was wondering what to do with the semFlush() calls that are being used on binary semaphores. Specifically, we're working on the Allen-Bradley DF1 driver.
Maybe what I should do is have a global counter that each thread increments before calling epicsEventWait(), and have the thread that calls epicsEventSignal() repeatedly signal and decrement the counter till it's zero..
Or is there a better way?
- Re: epicsEventSignal() question Henrique Almeida
- Re: epicsEventSignal() question Michael Westfall
- epicsEventSignal() question Michael Westfall
- Re: epicsEventSignal() question Andrew Johnson
Re: epicsEventSignal() question Till Straumann
motor: rval/lrvl double or long ? Torsten Bögershausen
<2016>
<2016>
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
