1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Error msg
To: <[email protected]>
Date: Fri, 3 Jun 2016 16:22:35 +0200
Hello Stefen,
I found _ZNSt9exceptionD2E (or demangled std::exception::~exception) in libstdc++.a in vxWorks 6.2, 6.3, 6.4, 6.6 and 6.7 (all vxWorks 6 I have). So If you include full C++ support in vxWorks, you should have it.
__gxx_personality_v0 is also in libstdc++.a but only in vxWorks 6.7. VxWorks 6.2 - 6.6 have __gxx_personality_sj0.
So If you have vxWorks 6.7 (or maybe higher) with C++ included, you should have the symbols.
Dirk
On 03.06.2016 15:41, Dirk Zimoch wrote:
Hi Stefen,
That basically says that your app1 makes use use of
std::exception::~exception and __gxx_personality_ but they are neither
defined in your code nor already loaded in in the system.
This is vxWorks, right?
Do you have full C++ support included in your vxWorks?
Dirk
On 03.06.2016 15:28, Stefen Paul wrote:
Hello all,
While running EPICS startup script st.cmd on vxWorks for an app that was
made successfully, I am getting following error :
/ld 0,0, "app1.munch"/
/Warning: module 0x23da5d0 holds reference to undefined symbol
_ZNSt9exceptionD2E/
/v./
__gxx_personality_/
/v0./
/ld(): module contains undefined symbol(s) and may be unusable./
/value = 0 = 0x0/
/Done executing startup script
'C:\EPICS\base\app1\iocBoot\iocapp1\st.cmd'/
Any clues what might me wrong ?
Stefen.
Re: Error msg Andrew Johnson
Re: Error msg Stefen Paul
Re: Error msg Dirk Zimoch
Prev: Re: Error msg Dirk Zimoch
Next: Re: Error msg Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
