1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: CSS vs. SSL
Date: Wed, 1 Jun 2016 09:43:03 +0000
I am using the CSS based RDB Channel Archiver and the PostgreSQL database – not under my control  - requires SSL on, at least the mode “required”.
When running the ArchiveConfigTool (3.2.15) how/where can I modify it to be “SSL-aware”?
Otherwise I get this error message:
$ ArchiveConfigTool -pluginCustomization settings_hades_scs_css_archive.ini -import -engine HadesArchiveEngine -config hadesArchive_css.xml -description HADES_Archiver -replace_engine
Importing     : hadesArchive_css.xml
Engine        : HadesArchiveEngine
Description   : HADES_Archiver
URL           : http://localhost:4812/main
Replace engine: true
Steal channels: false
2016-06-01 11:39:57.677 SEVERE [Thread 1] org.csstudio.archive.config.rdb.ArchiveConfigApplication (start) - Exception
org.postgresql.util.PSQLException: FATAL: client authentication failed
  Detail: no pool_hba.conf entry for host "140.181.75.165", user "hades_scs_css_archive", database "hades_scs_css_archive", SSL off
  Hint: see pgpool log for details
        at org.postgresql.core.v3.ConnectionFactoryImpl.doAuthentication(ConnectionFactoryImpl.java:408)
        at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:181)
        at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:64)
        at org.postgresql.jdbc2.AbstractJdbc2Connection.<init>(AbstractJdbc2Connection.java:144)
        at org.postgresql.jdbc3.AbstractJdbc3Connection.<init>(AbstractJdbc3Connection.java:29)
        at org.postgresql.jdbc3g.AbstractJdbc3gConnection.<init>(AbstractJdbc3gConnection.java:21)
        at org.postgresql.jdbc4.AbstractJdbc4Connection.<init>(AbstractJdbc4Connection.java:31)
        at org.postgresql.jdbc4.Jdbc4Connection.<init>(Jdbc4Connection.java:24)
        at org.postgresql.Driver.makeConnection(Driver.java:410)
        at org.postgresql.Driver.connect(Driver.java:280)
        at java.sql.DriverManager.getConnection(DriverManager.java:664)
        at java.sql.DriverManager.getConnection(DriverManager.java:247)
        at org.csstudio.platform.utility.rdb.internal.PostgreSQL_RDB.connect(PostgreSQL_RDB.java:44)
        at org.csstudio.platform.utility.rdb.RDBUtil.<init>(RDBUtil.java:179)
        at org.csstudio.platform.utility.rdb.RDBUtil.connect(RDBUtil.java:143)
        at org.csstudio.archive.config.rdb.RDBArchiveConfig.<init>(RDBArchiveConfig.java:80)
        at org.csstudio.archive.config.rdb.XMLImport.<init>(XMLImport.java:123)
        at org.csstudio.archive.config.rdb.ArchiveConfigApplication.start(ArchiveConfigApplication.java:207)
        at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:497)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
        at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Any help appreciated,
With best regards,
Peter
Dr. Peter Zumbruch
Experiment Electronics / Controls group
Phone / Telefon: +49-6159-71-1435
Fax: +49-6159-71-2986
E-Mail: [email protected]
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1, 64291 Darmstadt, Germany, www.gsi.de
Commercial Register / Handelsregister: Amtsgericht Darmstadt, HRB 1528
Managing Directors / Geschäftsführung:
Ursula Weyrich, Professor Dr. Karlheinz Langanke, Jörg Blaurock
Chairman of the Supervisory Board / Vorsitzender des GSI-Aufsichtsrats:
State Secretary / Staatssekretär Dr. Georg Schütte
Re: CSS vs. SSL Kasemir, Kay
Prev: Control System Engineer (ESS, Sweden) David Brodrick
Next: Re: Problems about Streamdevice when sending hex command to motor device Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: Re: CSS vs. SSL Kasemir, Kay
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
