1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Unable to tunnel CSS CA through ssh tunnels
To: "Kasemir, Kay" <[email protected]>
Date: Sun, 29 May 2016 02:41:35 +0000
Kay,
Several years ago Andre Charbonneau described how to tunnel CA
through ssh tunnels:
http://www.aps.anl.gov/epics/tech-talk/2013/msg00142.php
The method works well for EPICS base and extensions that use the EPICS
libraries.  It doesn't work with CSS because CSS doesn't use those libraries.
I think CSS uses Java CA.  I've searched the CSS documentation and the
Internet in vain.  Can it be done in the current version of CSS (4.1.1)?
If so, how?  If not, would you consider adding that functionality?
Jon
Dr. Jon Brinkmann, Factotum			Apache Point Observatory
Software Engineer				2001 Apache Point Road
Instrument Scientist				P.O. Box 59
E-mail:	[email protected]			Sunspot, NM 88349-0059
URL:	http://www.apo.nmsu.edu/brinkmann/	Tel: 575-437-6822
Re: Unable to tunnel CSS CA through ssh tunnels Till Straumann
Re: Unable to tunnel CSS CA through ssh tunnels Ralph Lange
Dynamically refresh CSS BOY runtime OPI Zhang Yuliang
RE: Dynamically refresh CSS BOY runtime OPI Mazanec Tomáš
RE: Dynamically refresh CSS BOY runtime OPI will.rogers
Re: Dynamically refresh CSS BOY runtime OPI Kasemir, Kay
Prev: RE: archiver appliance vs. data browser Schmeißer, Martin
Next: Re: Unable to tunnel CSS CA through ssh tunnels Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Dynamically refresh CSS BOY runtime OPI Andrew Johnson
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
