1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: NTP time provider and ticksPerSecond
Cc: Talk EPICS Tech <[email protected]>
Date: Tue, 17 May 2016 10:41:30 -1000
Hi Andrew,
Thanks. This patch is working. We'd like to stay up to date with EPICS releases but have no immediate plans for 3.15.
Is it feasible to include this into a 3.14.12.6 release?
-Matt
On Tue, May 17, 2016 at 6:24 AM, Andrew Johnson <[email protected]> wrote:
Hi Mike,
On 05/17/2016 11:05 AM, Michael Westfall wrote:
> Is there a way to delay initializing the NTP time provider until after
> my custom clock tick provider has set the system clock tick rate?
There was a change committed to the 3.15 branch of Base before 3.15.1 to
make the NTP time provider adjust automatically to changes in the system
clock tick rate. Changing the tick rate after iocInit is not advisable,
but in your case this change may be all you need. Since you're evidently
using a 3.14.12 release of Base you should be able to apply the attached
patch file to your copy.
HTH,
- Andrew
Re: NTP time provider and ticksPerSecond Andrew Johnson
NTP time provider and ticksPerSecond Michael Westfall
Prev: Re: NTP time provider and ticksPerSecond Michael Westfall
Next: Re: NTP time provider and ticksPerSecond Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
