1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: antelope error in Windows 7 cygwin build of EPICS base 3.15.3
Date: Fri, 6 May 2016 11:51:52 -0700
I'm trying to build EPICS base 3.15.3 on cygwin, on a Windows 7 host and getting errors when trying to build this.
I know there have been other threads about this on the forum, such as
http://www.aps.anl.gov/epics/tech-talk/2015/msg01742.php
with most problems being due to make, but I get the same error when I try two different makes:
make --version I get:
$ make --version
GNU Make 4.1
Built for x86_64-unknown-cygwin
or
The error output (shortened) are shown below:
g++ -o antelope.exe          -m32               epicsTempFile.obj closure.obj error.obj lalr.obj lr0.obj antelope.obj mkpar.obj output.obj reader.obj skeleton.obj symtab.obj verbose.obj warshall.obj
/usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-pc-cygwin/5.3.0//libstdc++.dll.a when searching for -lstdc++
/usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lstdc++
/usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-pc-cygwin/5.3.0//libgcc_s.dll.a when searching for -lgcc_s
/usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-pc-cygwin/5.3.0//libgcc.a when searching for -lgcc
/usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lgcc
/usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lcygwin
/usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/w32api/libadvapi32.a when searching for -ladvapi32
/usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -ladvapi32
/usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/w32api/libshell32.a when searching for -lshell32
/usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lshell32
/usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/w32api/libuser32.a when searching for -luser32
/usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -luser32
/usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: skipping incompatible /usr/lib/w32api/libkernel32.a when searching for -lkernel32
/usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lkernel32
/usr/lib/gcc/x86_64-pc-cygwin/5.3.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lgcc_s
collect2: error: ld returned 1 exit status
make[3]: *** No rule to make target 'antelope.exe', needed by '../../../bin/cygwin-x86/antelope.exe'.  Stop.
make[3]: Leaving directory '/cygdrive/c/Users/admx/epics/base/base-3.15.3/src/libCom/O.cygwin-x86'
../../configure/RULES_ARCHS:61: recipe for target 'install.cygwin-x86' failed
make[2]: *** [install.cygwin-x86] Error 2
make[2]: Leaving directory '/cygdrive/c/Users/admx/epics/base/base-3.15.3/src/libCom'
../configure/RULES_DIRS:88: recipe for target 'libCom.install' failed
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory '/cygdrive/c/Users/admx/epics/base/base-3.15.3/src'
configure/RULES_DIRS:88: recipe for target 'src.install' failed
make: *** [src.install] Error 2
Re: antelope error in Windows 7 cygwin build of EPICS base 3.15.3 Ana Malagon
Re: antelope error in Windows 7 cygwin build of EPICS base 3.15.3 Andrew Johnson
Prev: Re: Base 3.15.4-pre1 - URGENT call for beta testing Ralph Lange
Next: Re: antelope error in Windows 7 cygwin build of EPICS base 3.15.3 Ana Malagon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Match calloc() with free() for asynNDArrayDriver::pArrays Henrique Almeida
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
