1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Reg programming in EPICS environment for master slave control
Date: Thu, 5 May 2016 17:29:46 +0530
Thanks for your reply. I was able to program using the CP property in DOL field and was able to exchange the PVs between 2 IOCs deployed in the same system.
I wanted to know that how can I ensure that all the records process on a single user event like a button click (like update parameters in master control) so that PS controller receives the PVs at the same time from the master controller.
Regds,
Himanshu
On Wed, May 4, 2016 at 5:47 PM, Mark Rivers <[email protected]> wrote:
If your power supply IOC has a record like the following:
record(ao, "PSCurrent1")
   field(DOL,  ""MainControllerCurrent1 CP")
   field(OMSL, "closed_loop")
Then any time that the MainControllerCurrent1.VAL changes the PSCurrent1 record will update.
Sent: Wednesday, May 04, 2016 7:05 AM
To: Mark Rivers
Cc: EPICS Tech Talk
Time between the pulses is around 100 sec. The main controller should be able to transmit all the parameters to PS control in 100 ms on user request.
Can you please tell me about the CP property (I have never used it).
Regds,
Himanshu
On Wed, May 4, 2016 at 5:09 PM, Mark Rivers <[email protected]<redir.aspx?REF=kEXdxYCCr-FZUaL_ThshHBkVkM3HNl3ZEb9C7YBNKLtq8siAFXTTCAFtYWlsdG86cml2ZXJzQGNhcnMudWNoaWNhZ28uZWR1>> wrote:
What is the time between pulses?  How long does the main controller have to send all 100 parameters to the power supply controller?
Can the main controller just post the new parameters with Channel Access and the power supply controller use Channel Access links with CP property?  The power supply controller will then get all of the new values but only apply them just before the start of the next pulse?
From: Himanshu Tyagi [[email protected]<redir.aspx?REF=NuWGffECXUuAnd18S9ms4dhT2b63rqKRkwMTen-yuOFq8siAFXTTCAFtYWlsdG86aGltYW5zaHUudDBAZ21haWwuY29t>]
Sent: Wednesday, May 04, 2016 1:22 AM
To: Mark Rivers
Cc: EPICS Tech Talk
Dear Mark,
In actual I have around 100 configuration parameters which I have to pass to my Power supply controller. The pulse length is 1000sec and presently I am not considering the change in parameters during pulse.
The PS controller must respond within 100 ms to the set points sent by the main controller . If the parameters are accepted the status can be ready from PS control and if any parameter is not accepted the status can be error or any other state which can depict the issue.
Please let me know if you need any other information.
Regds,
Himanshu
On Tue, May 3, 2016 at 4:15 PM, Mark Rivers <[email protected]<redir.aspx?REF=kEXdxYCCr-FZUaL_ThshHBkVkM3HNl3ZEb9C7YBNKLtq8siAFXTTCAFtYWlsdG86cml2ZXJzQGNhcnMudWNoaWNhZ28uZWR1><redir.aspx?REF=NFc7nQy3xd8mw_XMSZxUv_SuToH6DNGtjvvmpUeuyLqU9OlKEHTTCAFtYWlsdG86cml2ZXJzQGNhcnMudWNoaWNhZ28uZWR1>> wrote:
Can you add some information about the performance requirements?
What is your pulse rate?
What is the frequency at which the main controller needs to pass that information to the power supply controllers?
What is the latency you can tolerate, i.e. how long after the main controller sends the information must be acted upon by the power supply controller?
From: [email protected]<redir.aspx?REF=yVfonvjqzvtM_LOEdjo3Dls7rQUy9pcLntU9YM_g7Hpq8siAFXTTCAFtYWlsdG86dGVjaC10YWxrLWJvdW5jZXNAYXBzLmFubC5nb3Y.><redir.aspx?REF=5_b7Y2U5zCtkHkRXw_nz_N3Er4QaKcezQyhyJGOe1_6U9OlKEHTTCAFtYWlsdG86dGVjaC10YWxrLWJvdW5jZXNAYXBzLmFubC5nb3Y.> [[email protected]<redir.aspx?REF=yVfonvjqzvtM_LOEdjo3Dls7rQUy9pcLntU9YM_g7Hpq8siAFXTTCAFtYWlsdG86dGVjaC10YWxrLWJvdW5jZXNAYXBzLmFubC5nb3Y.><redir.aspx?REF=5_b7Y2U5zCtkHkRXw_nz_N3Er4QaKcezQyhyJGOe1_6U9OlKEHTTCAFtYWlsdG86dGVjaC10YWxrLWJvdW5jZXNAYXBzLmFubC5nb3Y.>] on behalf of Himanshu Tyagi [[email protected]<redir.aspx?REF=NuWGffECXUuAnd18S9ms4dhT2b63rqKRkwMTen-yuOFq8siAFXTTCAFtYWlsdG86aGltYW5zaHUudDBAZ21haWwuY29t><redir.aspx?REF=TaRIMLMDeG082dKah6tSSsYF9lXCN4l7a9iS6TvNLeGU9OlKEHTTCAFtYWlsdG86aGltYW5zaHUudDBAZ21haWwuY29t>]
Sent: Tuesday, May 03, 2016 1:23 AM
To: EPICS Tech Talk
Subject: Reg programming in EPICS environment for master slave control
I have a requirement where the experimental facility has 2 controllers. The main experimental control and the power supply control.
The experiment has to be carried out in coordination of the 2 controllers. The main controller passes the configuration parameters to the power supply controller , which checks the validity of the parameters for the next pulse and apply them to the power supplies.
I want to implement this system using EPICS platform. Can any one provide me some ideas as to how to initiate such kind of control programming using EPICS.
I have some basic idea since I have interface Siemens plcs with EPICS but have not done the master -slave (2 controller) communication at EPICS level.
Pls suggest how such programs can be completed.
Himanshu
Himanshu Tyagi
Electronics Engg
Dept of Atomic Energy
P Please consider the environment before printing this e-mail
RE: Reg programming in EPICS environment for master slave control Mark Rivers
Reg programming in EPICS environment for master slave control Himanshu Tyagi
Re: Reg programming in EPICS environment for master slave control Himanshu Tyagi
Prev: Re: VisualDCT 2.6.1280 released Benjamin Franksen
Next: RE: Reg programming in EPICS environment for master slave control Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Reg programming in EPICS environment for master slave control Mark Rivers
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
