> On May 3, 2016, at 3:58 AM, lzfneu <[email protected]> wrote:
> First, thanks for your respond, the problem have been solved !
Good.
> and also the alarm tree with PV name shows:
> PV:SXFEL:RP:Gamma:02:RealDose:alarm (UNDEFINED/No Connection, UNDEFINED/No Connection)
Check your channel access address list, by this line in the file that you pass via the -pluginCustomization command line argument:
org.csstudio.platform.libs.epics/addr_list=..
By default, it starts out looking only on the local host (https://github.com/ControlSystemStudio/cs-studio/blame/master/applications/alarm/alarm-plugins/org.csstudio.alarm.beast.server/plugin_customization.ini)
See http://www.aps.anl.gov/epics/docs/ca.php for general channel access documentation, and refer to the docbook chapter named "Hierarchical Preferences”, http://cs-studio.sourceforge.net/docbook/ch06.html, for more on the -pluginCustomization files.
> Below is my test.xml file in details which imitate "org.csstudio.alarm.beast.configtool/demo/demo.xml". By the way, what is the <latching>true<latching> mean?
To use the alarm system, you should read the docbook chapter named "Alarm System”, see http://cs-studio.sourceforge.net/docbook/ch14.html:
"Alarm System Behavior
The alarm system will typically _latch_ alarms. This means ..”
-Kay
- Alarm Server start problem and how to compile JCA on Fedora20 64 bit system ? lzfneu
- Re: Alarm Server start problem and how to compile JCA on Fedora20 64 bit system ? Kasemir, Kay
- RE: Alarm Server start problem and how to compile JCA on Fedora20 64 bit system ? lzfneu
RE: Reg programming in EPICS environment for master slave control Mark Rivers
Send JMSAlarm Messages from BOY Panel Jensen Zelaya
<2016>
Reg programming in EPICS environment for master slave control Himanshu Tyagi
<2016>
