You concluded correctly that the alarm server cannot find the JCA binary.
You have two options:
1) Tell the alarm server to not use the native JCA binary, but instead the pure java CAJ implementation that's already included.
To do that, put this into the -pluginCustomization config file:
org.csstudio.platform.libs.epics/use_pure_java=true
That has actually been the default since summer 2012, see
https://github.com/ControlSystemStudio/cs-studio/blame/master/applications/alarm/alarm-plugins/org.csstudio.alarm.beast.server/plugin_customization.ini
2) Get the JCA binary and property install it.
If you decide to change the default alarm server setting because you prefer the native JCA library, that's fine, but then you need to build it and assert that it's found.
For building it, you'll have to check the ant file and the config files that come with the JCA sources.
You're likely missing some environment variable like EPICS_BASE_RELEASE.
For using it, you need to add the location of the JCA and EPICS binaries to the PATH (windows), LD_LIBRARY_PATH (Linux) or DYLD_LIBRARY_PATH (Mac OS X).
-Kay
hi,
I have two questions to consult you:
1) I enconter the following error messages (the details are shown below) when I start the Alarm Server by using the following command line on fedora20-64bit system and It seems that I miss JCA package , therefore I want to compile the JCA zip file that support
for 64bit system on website: https://sourceforge.net/p/epics-jca/jca/ci/default/tree/
Is my reasoning right ?
Here are the command line and error messages in details for question 1):
AlarmServer -pluginCustomization alarm_settings.ini
2016-05-02 22:22:10.866 INFO [Thread 1] org.csstudio.alarm.beast.server.Application (start) - Alarm Server 4.0.2.201507131348 started for 'Annunciator' configuration
Configuration Root: Annunciator
Database URL: jdbc:mysql://localhost/ALARM
JMS URL: failover:(tcp://localhost:61616)
JMS Server Topic: Annunciator_SERVER
JMS Client Topic: Annunciator_CLIENT
JMS Talk Topic: Annunciator_TALK
JMS Global Topic: GLOBAL_SERVER
2016-05-02 22:22:10.876 CONFIG [Thread 1] org.csstudio.vtype.pv.internal.Activator (start) - PV prefix pva provided by pva in org.csstudio.vtype.pv
2016-05-02 22:22:10.889 CONFIG [Thread 1] org.csstudio.platform.libs.epics.EpicsPlugin (start) - Cannot load Com and ca libraries. Could be a problem if JCA binary depends on them
java.lang.UnsatisfiedLinkError: no Com in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867)
at java.lang.Runtime.loadLibrary0(Runtime.java:870)
at java.lang.System.loadLibrary(System.java:1122)
at org.csstudio.platform.libs.epics.EpicsPlugin.start(EpicsPlugin.java:174)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319)
at org.eclipse.osgi.container.Module.doStart(Module.java:571)
at org.eclipse.osgi.container.Module.start(Module.java:439)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2671)
at java.lang.Class.getConstructor0(Class.java:3075)
at java.lang.Class.newInstance(Class.java:412)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.csstudio.vtype.pv.internal.Activator.start(Activator.java:44)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:391)
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:763)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:272)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:632)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:588)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:540)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:527)
at org.csstudio.alarm.beast.server.AlarmServer.<init>(AlarmServer.java:151)
at org.csstudio.alarm.beast.server.Application.start(Application.java:124)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
2016-05-02 22:22:10.892 SEVERE [Thread 1] org.csstudio.platform.libs.epics.EpicsPlugin (start) - Cannot load JCA binary
java.lang.UnsatisfiedLinkError: no jca in java.library.path
at org.csstudio.platform.libs.epics.EpicsPlugin.start(EpicsPlugin.java:188)
2016-05-02 22:22:10.894 CONFIG [Thread 1] org.csstudio.vtype.pv.internal.Activator (start) - PV prefix ca provided by ca in org.csstudio.vtype.pv
2016-05-02 22:22:10.894 CONFIG [Thread 1] org.csstudio.vtype.pv.internal.Activator (start) - PV prefix loc provided by loc in org.csstudio.vtype.pv
2016-05-02 22:22:10.896 CONFIG [Thread 1] org.csstudio.vtype.pv.internal.Activator (start) - Default PV type ca
Read 2 PVs in 0.02 seconds: 96.9 PVs/sec
2016-05-02 22:22:11.411 CONFIG [Thread 1] org.csstudio.vtype.pv.jca.JCAContext (<init>) - Using JNI JCA
2016-05-02 22:22:11.429 SEVERE [Thread 1] org.csstudio.alarm.beast.server.AlarmServer (startPVs) - Error starting PV PV1
java.lang.IllegalStateException: Context not initialized
at gov.aps.jca.jni.JNIContext._initialize(JNIContext.java:187)
at gov.aps.jca.jni.JNIContext.addContextMessageListener(JNIContext.java:303)
at org.csstudio.vtype.pv.jca.JCAContext.<init>(JCAContext.java:61)
at org.csstudio.vtype.pv.jca.JCAContext.getInstance(JCAContext.java:68)
at org.csstudio.vtype.pv.jca.JCA_PV.<init>(JCA_PV.java:101)
at org.csstudio.vtype.pv.jca.JCA_PVFactory.createPV(JCA_PVFactory.java:30)
at org.csstudio.vtype.pv.PVPool.createPV(PVPool.java:137)
at org.csstudio.vtype.pv.PVPool.getPV(PVPool.java:118)
at org.csstudio.alarm.beast.server.AlarmPV.start(AlarmPV.java:163)
at org.csstudio.alarm.beast.server.AlarmServer.startPVs(AlarmServer.java:354)
at org.csstudio.alarm.beast.server.AlarmServer.start(AlarmServer.java:281)
at org.csstudio.alarm.beast.server.Application.start(Application.java:132)
Caused by: gov.aps.jca.CAException: Unable to initialize context
at gov.aps.jca.jni.JNIContext.initialize(JNIContext.java:160)
at gov.aps.jca.jni.JNIContext._initialize(JNIContext.java:185)
... 24 more
Caused by: java.lang.UnsatisfiedLinkError: no jca in java.library.path
at gov.aps.jca.jni.JNI$1.run(JNI.java:100)
at gov.aps.jca.jni.JNI.init(JNI.java:110)
at gov.aps.jca.jni.JNIContext.initialize(JNIContext.java:149)
... 25 more
2016-05-02 22:22:11.430 CONFIG [Thread 1] org.csstudio.vtype.pv.jca.JCAContext (<init>) - Using JNI JCA
2016-05-02 22:22:11.432 SEVERE [Thread 1] org.csstudio.alarm.beast.server.AlarmServer (startPVs) - Error starting PV PV2
... 24 more
... 25 more
2) I also encounter errors when I compile unzaipped JCA package with ant command and the error message is: fatal error: epicsVersion.h: No such file or directory
It seems some configuration should be made with config.linux-x86_64.properties file in config folder.
But i don't know how to do.
Could you please help me and thanks in advance !
Zhefu
- RE: Alarm Server start problem and how to compile JCA on Fedora20 64 bit system ? lzfneu
- Alarm Server start problem and how to compile JCA on Fedora20 64 bit system ? lzfneu
Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Till Straumann
Re: EPICS 2016 Spring Meeting at ESS, Lund, Sweden Timo Korhonen
<2016>
<2016>
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
