I would be a little bit more
conservative and stress that this kind of thinking is very
dangerous.
Your scenario might work on a real-time system with properly
assigned priorities
"most of the time".
However, if you have e.g., an unprivileged IOC running under linux
then it will use
a time-sharing scheduler where every thread essentially has the
same priority and
can be preempted when it's time-slice is consumed. Under such a
scenario it can
happen that record processing is pre-empted and the IOC side of
caget
could interfere.
Even under a RTOS your assumption is dangerous: assume that the
caget thread
indeed has a lower priority than the record-processing one. It is
still possible
for the effective priority of caget to be raised above
record-processing e.g., as a
result of caget holding a priority-inheriting mutex on which a
high-priority thread
is waiting and then caget could preempt record-processing.
Properly written code should IMHO use either lockfree algorithms
or synchronization
devices and never rely on assumptions about scheduling for
synchronization.
The good news are that EPICS is properly written code in that
sense and caget
respects the database locking. So it is ensured that you never get
a field value
with an incorrect timestamp since both are read 'atomically' by
CA.
OTOH, you cannot read multiple fields atomically with caget
(AFAIK). I.e.,
if your record has fields 'A' and 'B' then you cannot be sure
caget(A); caget(B)
yields a consistent set. One could be new, one old.
There are work-arounds:
- you can use an 'array' field. All elements of an array are
accessed by CÁ atomically.
E.g., when you caget a waveform record then you always get a
consistent waveform
(with a consistent timestamp), never a half-old, half-new one.
- you could introduce locking semantics yourself. E.g., a 'LOCK'
field. Record
processing may not modify the essential fields while this is
set. The user then
has to caput(LOCK, 1); caget(FIELD1); caget(FIELD2), ...;
caput(LOCK, 0);
but you have to rely on the user observing the semantics.
-- Till
On 04/29/2016 09:56 PM, Mooney, Tim M. wrote:
Hi Dehong,
I don't think the IOC side of a caget is ever going to get
any CPU cycles while your record is processing unless you
voluntarily give up the processor - for example, by calling
asynchronous device support, or by waiting for something
(which record support isn't supposed to do anyway). If all
the fields that must be atomic are in the same record
instance, I think you're ok.
In my custom record, I need to update multiple fields
atomically so they stay
synchronized -- all updated, or none updated; not a few
updated, but a few with the
old data. If I use my own mutex, I suspect that
"caget" can cut in between the
updating and gets, for example, new data with old time
stamp, or old data with
new time stamp depending on the order of updating.
And I guess "camonitor" would not have this problem
because it would be the server
pushing the whole set (field itself and time stamp for
instance). Is this right?
So to close this hole with "caget", which global lock
should I use? dbScanLock?
Thank you, best regards,
Dehong
- Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Zhang, Dehong
- Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Zhang, Dehong
- RE: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Mooney, Tim M.
Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields bob dalesio
<2016>
<2016>
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
