1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields
To: "Zhang, Dehong" <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 30 Apr 2016 04:56:24 +0000
Hi Dehong,
I don't think the IOC side of a caget is ever going to get any CPU cycles while your record is processing unless you voluntarily give up the processor - for example, by calling asynchronous device support, or by waiting for something (which record support isn't supposed to do anyway).  If all the fields that must be atomic are in the same record instance, I think you're ok.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Zhang, Dehong [[email protected]]
Sent: Friday, April 29, 2016 6:12 PM
To: [email protected]
Subject: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields
In my custom record, I need to update multiple fields atomically so they stay
synchronized -- all updated, or none updated; not a few updated, but a few with the
old data.  If I use my own mutex, I suspect that "caget" can cut in between the
updating and gets, for example, new data with old time stamp, or old data with
new time stamp depending on the order of updating.
And I guess "camonitor" would not have this problem because it would be the server
pushing the whole set (field itself and time stamp for instance).  Is this right?
So to close this hole with "caget", which global lock should I use?  dbScanLock?
Thank you, best regards,
Dehong
Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Till Straumann
Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Zhang, Dehong
Prev: Re: Frame grabber for linux box Bruce Hill
Next: Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Zhang, Dehong
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
