1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: AW: Connection to Siemens S7 PLC
To: [email protected]
Date: Wed, 27 Apr 2016 13:53:38 +0200
Hi Jens and Saeed,
I asked nearly the same question few months ago on this tech talk. The principal obstacle I found is that I chose "old" material, a CPU 314C 2PN/DP. In the same time, by lack of experience I chose the last version of SIEMENS Software environnement, TIA Portal. With this configuration I failed to use the common solution advised, S7 PLC driver.
The "good vibrations" from T. JOANNEM (CEA Saclay), D. BRODRICK/N. LEVCHENKO (ESS) , R. LE GEN/E. M. TABAR (Australian Synchrotron) and P. TAYLOR pemitted me to progress in testing many cases. I take advantage of this mail to thank you again for all your precious help.
I finally arrived to establish a communication between EPICS and my PLC by building an IOC using the S7nodave driver. In fact you have not to declare or configure something in TIA Portal, that's why I think it worked with my CPU, and you don't need a 343-1 communication module, because you mentionned that your CPU has the PN port.
But, If you use old material with the old "STEP 7" software, I also recommand you to follow the Yu-Han Lin's PLC configuration document at http://epics.web.psi.ch/software/s7plc/, which would work fine with S7 PLC driver.
With the TIA PORTAL software I recommend to use S7-1200 or S7-1500 PLC at best wich permit a configuration of a new tcp communication required for building an ioc using S7 PLC driver.
Hope this will help you.
Best regards
Rémi FAURE
LPSC Grenoble-CNRS
Le 27/04/2016 10:30, Rekow, Jens a écrit :
Hi Saeed,
all of the 343-1 communication modules should work fine with the s7nodave driver. Actually if you have a S7-300 CPU with DN/DP you don't even need such a communication module because you can communicate in the same way with the Ethernet ports of the CPU directly.
Jens
Von: [email protected] [mailto:[email protected]] Im Auftrag von saeed haghtalab
Gesendet: Dienstag, 26. April 2016 22:20
An: [email protected]
Betreff: Connection to Siemens S7 PLC
Hi all,
I'm new to EPICS and I want to integrate the S7-300 PLC into EPICS. I have read that it can be done by S7 driver via TCP/IP module. But there is some kinds of these modules like 343-1 Lean, 343-1, 343-Advanced. Is there any difference between these kinds of modules in operating with S7 driver? Does CP343-1 Lean work well with s7nodave?
Best regards,
S. Haghtalab
RE: AW: Connection to Siemens S7 PLC Mueller, Joachim
Connection to Siemens S7 PLC saeed haghtalab
AW: Connection to Siemens S7 PLC Rekow, Jens
Prev: Re: caget always not found Ralph Lange
Next: Fw:Re:Re: caget always not found l123173
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: AW: Connection to Siemens S7 PLC Rekow, Jens
Next: RE: AW: Connection to Siemens S7 PLC Mueller, Joachim
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
