1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: caget always not found
To: [email protected]
Cc: l123173 <[email protected]>
Date: Wed, 27 Apr 2016 11:48:39 +0200
Hi Li,
These messages look like the pv name is indeed wrong.
If you do a "dbl" on your IOC - is the pv name that you want to reach really "${pv}"? That looks quite unusual.
Make sure you don't have spaces or illegal characters in the pv on the caget/cainfo command line.
Are you using the CA command line tools on the same host as the IOC, or on a different machine?
Cheers,
~Ralph
On 27/04/2016 10:24, l123173 wrote:
Hi all,
    I wonder why I failed and got message " Channel connect time out: ${pv} not found " or camonitor "*** Not connected (PV not found)", when I use caget, caput, camonitor.
    I added the path to environment and I can move the motor successfully with my ioc and the pv name isn't wront.
    Could you give some suggestion?
Li x
caget always not found l123173
Prev: AW: Connection to Siemens S7 PLC Rekow, Jens
Next: Re: AW: Connection to Siemens S7 PLC Remi Faure
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: caget always not found l123173
Next: Fw:Re:Re: caget always not found l123173
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
