1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS_TIMEZONE and TZ on RTEMS
To: Matt Rippa <[email protected]>, Talk EPICS Tech <[email protected]>
Date: Mon, 25 Apr 2016 17:28:22 -0500
On 4/25/16 4:12 PM, Matt Rippa wrote:
> Hello,
> On EPICS 3.14.12.4 and RTEMS 4.10.2 I can't seem to control the
> timezone at runtime.
> My BSP is the mvme2700.
> EPICS base is build with
> base/configure/CONFIG_SITE_ENV:EPICS_TIMEZONE=CUS::360:031302:110602
> An oversight, but I was thinking it didn't matter and I could just
> change things in my startup script. I tried to re-define this in my
> startup script before iocInit() as follows:
> #Hawaii is standard time and never moves their clocks
> epicsEnvSet("EPICS_TIMEZONE", "HST::600:0:0")
Hello, Matt.
I don't think that's a valid value: the last two parts are supposed to
be "mmddhh", but you've just got a single digit ('0') for each.
> Then I found the link below so I tried
> epicsEnvSet("TZ", "HST10")
> In both cases, my timezone persisted with Central US time, UTC-5
> hours.
On VxWorks, I set the "TIMEZONE" environment variable instead of
"EPICS_TIMEZONE".  I suspect there's a reason for that, but I don't
remember what it is, and I don't know if the same applies to RTEMS.
> My latest AppDevGuide (Oct. 5th, 2015) does not describe it.  Is this
> documented anywhere else?
The documentation I've been using is the comment for EPICS_TIMEZONE in
configure/CONFIG_SITE_ENV.
Lewis
Re: EPICS_TIMEZONE and TZ on RTEMS Matt Rippa
Prev: Xming MEDM scaled fonts pthomas
Next: Re: EPICS_TIMEZONE and TZ on RTEMS Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: EPICS_TIMEZONE and TZ on RTEMS Matt Rippa
Next: Re: EPICS_TIMEZONE and TZ on RTEMS Matt Rippa
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
