It's better not to change rmem_default, or most sockets in the system will have an increased buffer size. Instead, using setsockopt() will increase the buffer size only for the camera.
Also, a 1 MB buffer may not be enough, since it represents a 8 ms buffer in a 1 Gbps network. It is common for an application to be preempted for dozens of milliseconds under heavy load. I'm currently testing 2 MB for our non-GigE camera server. Our camera, however, does not support packet retransmissions, while the GigE protocol does.
Em 21/04/2016 15:19, "Mark Rivers" < [email protected]> escreveu:
Folks,
I find that people frequently have problems with dropped frames when running GigE cameras on Linux, particularly under heavy CPU loading.
In 2013 I posted a message to tech-talk (http://www.aps.anl.gov/epics/tech-talk/2013/msg02491.php)
about this problem. It contained a link from Tom Cobb to a Point Grey Knowledge Base article with a solution, which involves increasing some system values as follows:
sudo sysctl -w net.core.rmem_max=1048576 net.core.rmem_default=1048576
I found today that the Point Grey link in that message no longer works. However, here is a new link that does work.
http://www.ptgrey.com/KB/10016
- RE: Dropped frames from GigE cameras on Linux Mark Rivers
- Dropped frames from GigE cameras on Linux Mark Rivers
Brookhaven National Laboratory - Job Opening Esposito, Peter J
<2016>
<2016>
