Hi Kathryn,
On 04/14/2016 10:43 AM, [email protected] wrote:
> I have just written an Asyn driver for the Lambda TDK Genesys power
> supply, and I got it working after realising that before I can get it to
> do anything with comms I have to address it properly. This is RS232
> comms, but for some reason these PSUs seem to demand that the first
> command I send it when trying to interact with it is an “ADR” command
> with its RS485 address.
You are using the RS232 interface, but it might be good to ensure that
your driver works with RS485-connected devices on a shared bus. I'm not
sure what the standard Asyn way is of doing that, but you may have to
include the ADR command in the Stream protocol as part of every command
(since some other record that addresses a different device may get
processed in between sending your command strings). Mark Rivers' answer
may be a better solution for the RS232-only or non-shared RS485 case.
> So, the simple version of the question:
> Does PINI respect the PHAS field?
Yes, since R3.14.11 — the RELEASE_NOTES.html file for any Base-3.14
version since then has a discussion on those changes.
- Andrew
There are only two hard problems in distributed systems:
2. Exactly-once delivery
1. Guaranteed order of messages
-- Mathias Verraes
- RE: Force one record to run before all others kathryn.baker
- Re: Force one record to run before all others Michael Davidsaver
- Force one record to run before all others kathryn.baker
RE: Force one record to run before all others Mark Rivers
Re: Force one record to run before all others Eric Norum
<2016>
<2016>
