1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: set baud rate not work
To: 梁雅翔 <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 5 Apr 2016 11:41:19 +0000
> I found that I received the right information only when I set the baud rate was 9600. It get nothing when the baud rate was 115200.
This is unclear.  When you say "set the baud rate was 9600" do you mean the baud rate on the other computer, or do you mean in the asynSetOption command in this IOC?
Are you sure that the IOC computer actually supports baud 115200?  Not all computers do.
What OS and version are you running on the IOC computer?
Are there any error messages on the IOC when you run those commands?
From: [email protected] [[email protected]] on behalf of 梁雅翔 [[email protected]]
Sent: Tuesday, April 05, 2016 2:51 AM
To: [email protected]
Subject: set baud rate not work
Hi everyone,
   I have a strange question.
   I use the stream and asyn to control a device. epics 3.1.12.5,synApp_5_8.
   I set the baud of serial in 115200 in st.cmd with these commands:
epicsEnvSet "TTY" "$(TTY=/dev/ttyS1)"
drvAsynSerialPortConfigure("L0","$(TTY)",0,0,0)
asynSetOption("L0",-1,"baud","115200")
asynSetOption("L0",-1,"bits","8")
asynSetOption("L0",-1,"parity","none")
asynSetOption("L0",-1,"stop","1")
asynSetOption("L0",-1,"clocal","Y")
asynSetOption("L0",-1,"crtscts","N")
asynOctetSetInputEos("L0",-1,"\r\n")
asynOctetSetOutputEos("L0",-1,"\r\n")
asynSetTraceIOMask("L0",-1,0x2)
asynSetTraceMask("L0",-1,0x9)
   Then I start the st.cmd and communicate it with another xp computer, using Serial port assistant.
And it should be 115200, I failed when i used it in device directly.
I did set it was 115200 in st.cmd, why it did not work.
Liang yx
set baud rate not work 梁雅翔
Prev: Re: Controlling vacuum valves with EPICS Joachim Rahn
Next: RE: Controlling vacuum valves with EPICS Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: set baud rate not work 梁雅翔
Next: RE: set baud rate not work Mark S. Engbretson
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
