1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Multiple layers of DB templates?
To: [email protected]
Date: Mon, 4 Apr 2016 13:49:49 -0700
Hi Martin,
I think the dbLoad* routines only support simple macro substitution and not the full msi feature set, so I think you're best trying to do this at build time by invoking
msi twice.
The .db and .substitutions suffixes are significant as RULES.Db knows how to build %.db from %.substitutions, but I think you can use anything in place of .template,
including another .db.
I solved this need for multiple substitutions several years ago by creating a new %.db: %.sub2 rule in my local Db/Makefile, but I think it's easier to do this by having two directories. For example, you could create a module for your device that builds mydevice.db, and then your ioc Db directory could have another substitutions file
that creates a single db file w/ all 60 instances.
You could also create a deviceDb folder in your ioc/*App directory as long as you
add a dependency so deviceDb gets built before Db.
Cheers,
- Bruce
On 4/4/2016 11:43 AM, Konrad, Martin wrote:
Hi all,
I need to create an EPICS database for a soft IOC with 60 identical
devices. Each of these devices has a set of records that are identical
for multiple inputs. Having the DRY pattern in mind, I was wondering if
I could somehow use two levels of DB templates. Here is what I have in mind:
st.cmd:
dbLoadTemplate("myproject.substitutions")
myproject.substitutions:
global { SYS=...,SUBSYS=... }
file mydevice.db {
    pattern { ... }
mydevice.db:
<some records here>
substitute "INPUT=1"
include "myinput.db"
substitute "INPUT=2"
myinput.db:
<a couple of records needed for each input>
A manual run of MSI tool on mydevice.db handles both the "substitute"
and the "include" keyword correctly but by default macro expansion is
done at dbLoadTemplate time. This however results in
Error: syntax error
   at or before "substitute" in file "mydevice.db" line 16
It seems like dbLoadTemplate doesn't support the "substitute" keyword. I
found a BNF definition of the substitution file format in chapter 6.12.1
of the Application Developer's Guide [1]. Unfortunately I did not find a
definition like this for DB files/templates. Can you please help me out
here?
I am aware that I could use 60 dbLoadTemplate lines instead (that would
clutter IOC boot output, though). I could also pull in both mydevice.db
and myinput.db from the substitutions file directly - but for that I
need to add N lines referring to myinput.db in the substitution file for
each line referring to mydevice.db (assuming a device with N inputs). Is
there a nicer way to do this?
Thanks a lot,
Martin
P.S.: BTW: Is there a difference between a DB file and a template? Are
their file names supposed to have different suffix (".template" vs. ".db"?
[1] http://www.aps.anl.gov/epics/base/R3-15/3-docs/AppDevGuide.pdf
Multiple layers of DB templates? Konrad, Martin
Prev: Re: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Steve Shoaf
Next: Re: Multiple layers of DB templates? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Multiple layers of DB templates? Konrad, Martin
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
