Hi Tim,
One minor correction, for the record:
On 03/31/2016 01:03 PM, Madden, Timothy J. wrote:
> 5) Edit CONFIG_SITE.Common.linux-x86_64 and CONFIG_SITE.Common.linux-x86 and comment out
> #COMMANDLINE_LIBRARY = READLINE
> There is no readline on arm systems...
To disable linking with libreadline for your target build, the relevant
setting is actually found in the CONFIG_SITE.Common.linux-arm file; the
above just disables the use of libreadline with the host build. The
readline library *is* available on many linux-arm targets, but the
current default in Base for linux-arm requires you to explicitly enable
readline if you have it.
- Andrew
There are only two hard problems in distributed systems:
2. Exactly-once delivery
1. Guaranteed order of messages
-- Mathias Verraes
- RE: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Madden, Timothy J.
Re: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe D Peter Siddons
<2016>
PCaPAC 2016 James Rezende Piton
<2016>
