Don’t you want to do
EPICS_HOST_ARCH linux-x86_64
and in
base/configure/CONFIG_SITE
set
CROSS_COMPILER_TARGET_ARCHS=linux-arm
CROSS_COMPILER_HOST_ARCHS=linux-x86_64
Folks
I am attempting to build EPICS into Xilinx Zynq FPGA. I am using petalinux tools (the xilinx distro of linux) to build in EPICS base.
First I go through setting up the Xilinx petalinux compiler etc. All my tools work fine. Next I attempt to cross compile epics base using the Xilinx cross compiler. It works about half way then stops at antelope.
I do this:
setenv EPICS_HOST_ARCH linux-arm
I edit configure/CONFIG_SITE and add the following lines:
GNU_DIR = /localc/Xilinx/petalinux-v2015.2-final/tools/linux-i386/arm-xilinx-linux-gnueabi
CMPLR_PREFIX = arm-xilinx-linux-gnueabi-
(I tried putting this into the os/CONFIG.blah blah files, but no success.)
I then run make in base.xx.xx.xx
The build mostly works, running the correct compiler. .
It stops at antelope/parse.c
Error below. Any ideas how to get past antelope?
Tim Madden
/localc/Xilinx/petalinux-v2015.2-final/tools/linux-i386/arm-xilinx-linux-gnueabi/bin/arm-xilinx-linux-gnueabi-gcc -c -D_GNU_SOURCE -D_DEFAULT_SOURCE -DDEFAULT_SKELETON_FILE=include/flex.skel.static -DUNIX -Dlinux -O3 -g -w -MMD
-I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../tblcmp.c
rm -f parse.c y.tab.c
rm -f parse.h y.tab.h
../../../../bin/linux-arm/antelope -l -d ../parse.y
../../../../bin/linux-arm/antelope: ../../../../bin/linux-arm/antelope: cannot execute binary file
make[4]: *** [parse.c] Error 126
make[4]: Leaving directory `/localc/Xilinx/petalinux/faspaxGBArm/build/linux/rootfs/apps/epicsbase/base-3.14.12.5/src/toolsComm/flex/O.linux-arm'
make[3]: *** [install.linux-arm] Error 2
make[3]: Leaving directory `/localc/Xilinx/petalinux/faspaxGBArm/build/linux/rootfs/apps/epicsbase/base-3.14.12.5/src/toolsComm/flex'
make[2]: *** [flex.install] Error 2
make[2]: Leaving directory `/localc/Xilinx/petalinux/faspaxGBArm/build/linux/rootfs/apps/epicsbase/base-3.14.12.5/src/toolsComm'
make[1]: *** [toolsComm.install] Error 2
make[1]: Leaving directory `/localc/Xilinx/petalinux/faspaxGBArm/build/linux/rootfs/apps/epicsbase/base-3.14.12.5/src'
make: *** [src.install] Error 2
- RE: Cross compiling EPICS Base for ARM processor- Xilinx ARM Petalinux- Antelope Error Madden, Timothy J.
- Cross compiling EPICS Base for ARM processor- Xilinx ARM Petalinux- Antelope Error Madden, Timothy J.
<2016>
<2016>
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
