1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Cross compiling EPICS Base for ARM processor- Xilinx ARM Petalinux- Antelope Error
Date: Thu, 31 Mar 2016 15:37:54 +0000
Folks
I am attempting to build EPICS into Xilinx Zynq FPGA. I am using petalinux tools (the xilinx distro of linux) to build in EPICS base.
First I go through setting up the Xilinx petalinux compiler etc. All my tools work fine. Next I attempt to cross compile epics base using the Xilinx cross compiler. It works about half way then stops at antelope.
I do this:
setenv EPICS_HOST_ARCH linux-arm
I edit configure/CONFIG_SITE and add the following lines:
GNU_DIR = /localc/Xilinx/petalinux-v2015.2-final/tools/linux-i386/arm-xilinx-linux-gnueabi
CMPLR_PREFIX =  arm-xilinx-linux-gnueabi-
(I tried putting this into the os/CONFIG.blah blah files, but no success.)
I then run make in base.xx.xx.xx
The build mostly works, running the correct compiler. .
It stops at antelope/parse.c
Error below. Any ideas how to get past antelope?
Tim Madden
/localc/Xilinx/petalinux-v2015.2-final/tools/linux-i386/arm-xilinx-linux-gnueabi/bin/arm-xilinx-linux-gnueabi-gcc -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DDEFAULT_SKELETON_FILE=include/flex.skel.static    -DUNIX  -Dlinux     -O3 -g   -w            -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../tblcmp.c
rm -f parse.c y.tab.c
rm -f parse.h y.tab.h
../../../../bin/linux-arm/antelope -l -d ../parse.y
../../../../bin/linux-arm/antelope: ../../../../bin/linux-arm/antelope: cannot execute binary file
make[4]: *** [parse.c] Error 126
make[4]: Leaving directory `/localc/Xilinx/petalinux/faspaxGBArm/build/linux/rootfs/apps/epicsbase/base-3.14.12.5/src/toolsComm/flex/O.linux-arm'
make[3]: *** [install.linux-arm] Error 2
make[3]: Leaving directory `/localc/Xilinx/petalinux/faspaxGBArm/build/linux/rootfs/apps/epicsbase/base-3.14.12.5/src/toolsComm/flex'
make[2]: *** [flex.install] Error 2
make[2]: Leaving directory `/localc/Xilinx/petalinux/faspaxGBArm/build/linux/rootfs/apps/epicsbase/base-3.14.12.5/src/toolsComm'
make[1]: *** [toolsComm.install] Error 2
make[1]: Leaving directory `/localc/Xilinx/petalinux/faspaxGBArm/build/linux/rootfs/apps/epicsbase/base-3.14.12.5/src'
make: *** [src.install] Error 2
RE: Cross compiling EPICS Base for ARM processor- Xilinx ARM Petalinux- Antelope Error Mark Rivers
Prev: IOC for Rohde & Schwarz FSV Vitor Finotti
Next: RE: Cross compiling EPICS Base for ARM processor- Xilinx ARM Petalinux- Antelope Error Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
