1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: About Pilatus IOC Error Messgae..
To: mujin park <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 29 Mar 2016 10:37:44 +0000
Please tell us:
- Why you are changing the Pilatus driver?  What are you trying to do that the existing driver does not do?
- What did you change?  Do not send the complete file like you did.  Rather, send the output of "diff -U3" or "git diff" comparing your version to the original version.
The error message looks like files have been opened without then closing them, but without being able to see exactly what you changed it is hard to know.
From: [email protected] [[email protected]] on behalf of mujin park [[email protected]]
Sent: Tuesday, March 29, 2016 2:01 AM
To: [email protected]
Subject: About Pilatus IOC Error Messgae..
hellow
i modified the pilatus src like this
For changing the last made filename...
/* pilatusDetector.cpp
 * This is a driver for a Pilatus pixel array detector.
 * Author: Mark Rivers
 *         University of Chicago
 * Created:  June 11, 2008
#include <stddef.h>
#include <stdlib.h>
#include <stdarg.h>
#include <math.h>
#include <stdio.h>
#include <errno.h>
#include <string.h>
#include <ctype.h>
#include <fcntl.h>
#include <sys/stat.h>
#include <unistd.h>
#include <cbf_ad.h>
#include <tiffio.h>
#include <epicsTime.h>
#include <epicsThread.h>
#include <epicsEvent.h>
#include <epicsMutex.h>
#include <epicsString.h>
#include <epicsStdio.h>
#include <cantProceed.h>
#include <iocsh.h>
#include <epicsExport.h>
#include <asynOctetSyncIO.h>
#include "ADDriver.h"
/** Messages to/from camserver */
#define MAX_MESSAGE_SIZE 256
#define MAX_FILENAME_LEN 256
#define FILEPATH_INDEX 8
#define MAX_BAD_PIXELS 100
/** Time to poll when reading from camserver */
#define ASYN_POLL_TIME .01
/**#define CAMSERVER_DEFAULT_TIMEOUT 1**/
/** Time between checking to see if image file is complete */
#define FILE_READ_DELAY .01
/** Trigger modes */
typedef enum {
    TMInternal,
    TMExternalEnable,
    TMExternalTrigger,
    TMMultipleExternalTrigger,
    TMAlignment
} PilatusTriggerMode;
/** Bad pixel structure for Pilatus detector */
typedef struct {
    int badIndex;
    int replaceIndex;
} badPixel;
static const char *gainStrings[] = {"lowG", "midG", "highG", "uhighG"};
static const char *driverName = "pilatusDetector";
#define PilatusDelayTimeString      "DELAY_TIME"
#define PilatusThresholdString      "THRESHOLD"
#define PilatusThresholdApplyString "THRESHOLD_APPLY"
#define PilatusThresholdAutoApplyString "THRESHOLD_AUTO_APPLY"
#define PilatusArmedString          "ARMED"
#define PilatusImageFileTmotString  "IMAGE_FILE_TMOT"
#define PilatusBadPixelFileString   "BAD_PIXEL_FILE"
#define PilatusNumBadPixelsString   "NUM_BAD_PIXELS"
#define PilatusFlatFieldFileString  "FLAT_FIELD_FILE"
#define PilatusMinFlatFieldString   "MIN_FLAT_FIELD"
#define PilatusFlatFieldValidString "FLAT_FIELD_VALID"
#define PilatusGapFillString        "GAP_FILL"
#define PilatusWavelengthString     "WAVELENGTH"
#define PilatusEnergyLowString      "ENERGY_LOW"
#define PilatusEnergyHighString     "ENERGY_HIGH"
#define PilatusDetDistString        "DET_DIST"
#define PilatusDetVOffsetString     "DET_VOFFSET"
#define PilatusBeamXString          "BEAM_X"
#define PilatusBeamYString          "BEAM_Y"
#define PilatusFluxString           "FLUX"
#define PilatusFilterTransmString   "FILTER_TRANSM"
#define PilatusStartAngleString     "START_ANGLE"
#define PilatusAngleIncrString      "ANGLE_INCR"
#define PilatusDet2thetaString      "DET_2THETA"
#define PilatusPolarizationString   "POLARIZATION"
#define PilatusAlphaString          "ALPHA"
#define PilatusKappaString          "KAPPA"
#define PilatusPhiString            "PHI"
#define PilatusChiString            "CHI"
#define PilatusOscillAxisString     "OSCILL_AXIS"
#define PilatusNumOscillString      "NUM_OSCILL"
/** Driver for Dectris Pilatus pixel array detectors using their camserver server over TCP/IP socket */
class pilatusDetector : public ADDriver {
public:
    pilatusDetector(const char *portName, const char *camserverPort,
                    int maxSizeX, int maxSizeY,
                    int maxBuffers, size_t maxMemory,
                    int priority, int stackSize);
    /* These are the methods that we override from ADDriver */
    virtual asynStatus writeInt32(asynUser *pasynUser, epicsInt32 value);
    virtual asynStatus writeFloat64(asynUser *pasynUser, epicsFloat64 value);
    virtual asynStatus writeOctet(asynUser *pasynUser, const char *value,
                                    size_t nChars, size_t *nActual);
    void report(FILE *fp, int details);
    void pilatusTask(); /* This should be private but is called from C so must be public */
 protected:
    int PilatusDelayTime;
    #define FIRST_PILATUS_PARAM PilatusDelayTime
    int PilatusThreshold;
    int PilatusThresholdApply;
    int PilatusThresholdAutoApply;
    int PilatusArmed;
    int PilatusImageFileTmot;
    int PilatusBadPixelFile;
    int PilatusNumBadPixels;
    int PilatusFlatFieldFile;
    int PilatusMinFlatField;
    int PilatusFlatFieldValid;
    int PilatusGapFill;
    int PilatusWavelength;
    int PilatusEnergyLow;
    int PilatusEnergyHigh;
    int PilatusDetDist;
    int PilatusDetVOffset;
    int PilatusBeamX;
    int PilatusBeamY;
    int PilatusFlux;
    int PilatusFilterTransm;
    int PilatusStartAngle;
    int PilatusAngleIncr;
    int PilatusDet2theta;
    int PilatusPolarization;
    int PilatusAlpha;
    int PilatusKappa;
    int PilatusPhi;
    int PilatusChi;
    int PilatusOscillAxis;
    int PilatusNumOscill;
    #define LAST_PILATUS_PARAM PilatusNumOscill
 private:
    /* These are the methods that are new to this class */
    void abortAcquisition();
    void makeMultipleFileFormat(const char *baseFileName);
    asynStatus waitForFileToExist(const char *fileName, epicsTimeStamp *pStartTime, double timeout, NDArray *pImage);
    void correctBadPixels(NDArray *pImage);
    int stringEndsWith(const char *aString, const char *aSubstring, int shouldIgnoreCase);
    asynStatus readImageFile(const char *fileName, epicsTimeStamp *pStartTime, double timeout, NDArray *pImage);
    asynStatus readCbf(const char *fileName, epicsTimeStamp *pStartTime, double timeout, NDArray *pImage);
    asynStatus readTiff(const char *fileName, epicsTimeStamp *pStartTime, double timeout, NDArray *pImage);
    asynStatus writeCamserver(double timeout);
    asynStatus readCamserver(double timeout);
    asynStatus writeReadCamserver(double timeout);
    asynStatus setAcquireParams();
    asynStatus setThreshold();
    void readBadPixelFile(const char *badPixelFile);
    void readFlatFieldFile(const char *flatFieldFile);
    /* Our data */
    int imagesRemaining;
    epicsEventId startEventId;
    epicsEventId stopEventId;
    char toCamserver[MAX_MESSAGE_SIZE];
    char fromCamserver[MAX_MESSAGE_SIZE];
    NDArray *pFlatField;
    char multipleFileFormat[MAX_FILENAME_LEN];
    int multipleFileNumber;
    int multipleFileNumber2;
    asynUser *pasynUserCamserver;
    badPixel badPixelMap[MAX_BAD_PIXELS];
    double averageFlatField;
#define NUM_PILATUS_PARAMS (&LAST_PILATUS_PARAM - &FIRST_PILATUS_PARAM + 1)
void pilatusDetector::readBadPixelFile(const char *badPixelFile)
    int i;
    int xbad, ybad, xgood, ygood;
    int n;
    FILE *file;
    int nx, ny;
    const char *functionName = "readBadPixelFile";
    int numBadPixels=0;
    getIntegerParam(NDArraySizeX, &nx);
    getIntegerParam(NDArraySizeY, &ny);
    setIntegerParam(PilatusNumBadPixels, numBadPixels);
    if (strlen(badPixelFile) == 0) return;
    file = fopen(badPixelFile, "r");
    if (file == NULL) {
        asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
            "%s::%s, cannot open file %s\n",
            driverName, functionName, badPixelFile);
        return;
    for (i=0; i<MAX_BAD_PIXELS; i++) {
        n = fscanf(file, " %d,%d %d,%d",
                  &xbad, &ybad, &xgood, &ygood);
        if (n == EOF) break;
        if (n != 4) {
                "%s::%s, too few items =%d, should be 4\n",
                driverName, functionName, n);
            return;
        this->badPixelMap[i].badIndex = ybad*nx + xbad;
        this->badPixelMap[i].replaceIndex = ygood*ny + xgood;
        numBadPixels++;
void pilatusDetector::readFlatFieldFile(const char *flatFieldFile)
    int i;
    int status;
    int ngood;
    int minFlatField;
    epicsInt32 *pData;
    const char *functionName = "readFlatFieldFile";
    NDArrayInfo arrayInfo;
    setIntegerParam(PilatusFlatFieldValid, 0);
    this->pFlatField->getInfo(&arrayInfo);
    getIntegerParam(PilatusMinFlatField, &minFlatField);
    if (strlen(flatFieldFile) == 0) return;
    status = readImageFile(flatFieldFile, NULL, 0., this->pFlatField);
    if (status) {
            "%s::%s, error reading flat field file %s\n",
            driverName, functionName, flatFieldFile);
        return;
    /* Compute the average counts in the flat field */
    this->averageFlatField = 0.;
    ngood = 0;
    for (i=0, pData = (epicsInt32 *)this->pFlatField->pData;
         i<arrayInfo.nElements;
         i++, pData++) {
        if (*pData < minFlatField) continue;
        ngood++;
        averageFlatField += *pData;
    averageFlatField = averageFlatField/ngood;
         i++, pData++) {
        if (*pData < minFlatField) *pData = (epicsInt32)averageFlatField;
    /* Call the NDArray callback */
    /* Must release the lock here, or we can get into a deadlock, because we can
     * block on the plugin lock, and the plugin can be calling us */
    this->unlock();
    doCallbacksGenericPointer(this->pFlatField, NDArrayData, 0);
    this->lock();
    setIntegerParam(PilatusFlatFieldValid, 1);
void pilatusDetector::makeMultipleFileFormat(const char *baseFileName)
    /* This function uses the code from camserver */
    char *p, *q;
    int fmt;
    char mfTempFormat[MAX_FILENAME_LEN];
    char mfExtension[10];
    int numImages;
    /* baseFilename has been built by the caller.
     * Copy to temp */
    strncpy(mfTempFormat, baseFileName, sizeof(mfTempFormat));
    getIntegerParam(ADNumImages, &numImages);
    p = mfTempFormat + strlen(mfTempFormat) - 5; /* look for extension */
    if ( (q=strrchr(p, '.')) ) {
        strcpy(mfExtension, q);
        *q = '\0';
    } else {
        strcpy(mfExtension, ""); /* default is raw image */
    multipleFileNumber=0;   /* start number */
    fmt=5;        /* format length */
    if ( !(p=strrchr(mfTempFormat, '/')) ) {
        p=mfTempFormat;
    if ( (q=strrchr(p, '_')) ) {
        q++;
        if (isdigit(*q) && isdigit(*(q+1)) && isdigit(*(q+2))) {
            multipleFileNumber=atoi(q);
            fmt=0;
            p=q;
            while(isdigit(*q)) {
                fmt++;
                q++;
            *p='\0';
            if (((fmt<3)  || ((fmt==3) && (numImages>999))) ||
                ((fmt==4) && (numImages>9999))) {
                fmt=5;
        } else if (*q) {
            strcat(p, "_"); /* force '_' ending */
    } else {
    /* Build the final format string */
    epicsSnprintf(this->multipleFileFormat, sizeof(this->multipleFileFormat), "%s%%.%dd%s",
                  mfTempFormat, fmt, mfExtension);
/** This function waits for the specified file to exist.  It checks to make sure that
 * the creation time of the file is after a start time passed to it, to force it to wait
 * for a new file to be created.
asynStatus pilatusDetector::waitForFileToExist(const char *fileName, epicsTimeStamp *pStartTime, double timeout, NDArray *pImage)
    int fd=-1;
    int fileExists=0;
    struct stat statBuff;
    epicsTimeStamp tStart, tCheck;
    time_t acqStartTime;
    double deltaTime=0.;
    int status=-1;
    const char *functionName = "waitForFileToExist";
    FILE *fp;
    if (pStartTime) epicsTimeToTime_t(&acqStartTime, pStartTime);
    epicsTimeGetCurrent(&tStart);
    while (deltaTime <= timeout) {
        fd = open(fileName, O_RDONLY, 0);
        if ((fd >= 0) && (timeout != 0.)) {
            fileExists = 1;
            status = fstat(fd, &statBuff);
            if (status){
                    "%s::%s error calling fstat, errno=%d %s\n",
                    driverName, functionName, errno, fileName);
                close(fd);
                return(asynError);
            if (difftime(statBuff.st_mtime, acqStartTime) > -1) break;
            close(fd);
            fd = -1;
        /* Sleep, but check for stop event, which can be used to abort a long acquisition */
        status = epicsEventWaitWithTimeout(this->stopEventId, FILE_READ_DELAY);
        if (status == epicsEventWaitOK) {
            setStringParam(ADStatusMessage, "Acquisition aborted");
            return(asynError);
        epicsTimeGetCurrent(&tCheck);
        deltaTime = epicsTimeDiffInSeconds(&tCheck, &tStart);
    if (fd < 0) {
            "%s::%s timeout waiting for file to be created %s\n",
            driverName, functionName, fileName);
        if (fileExists) {
                "  file exists but is more than 10 seconds old, possible clock synchronization problem\n");
            setStringParam(ADStatusMessage, "Image file is more than 10 seconds old");
        } else
            setStringParam(ADStatusMessage, "Timeout waiting for file to be created");
        return(asynError);
    close(fd);
    return(asynSuccess);
/** This function replaces bad pixels in the specified image with their replacements
 * according to the bad pixel map.
void pilatusDetector::correctBadPixels(NDArray *pImage)
    int i;
    int numBadPixels;
    getIntegerParam(PilatusNumBadPixels, &numBadPixels);
    for (i=0; i<numBadPixels; i++) {
        ((epicsInt32 *)pImage->pData)[this->badPixelMap[i].badIndex] =
        ((epicsInt32 *)pImage->pData)[this->badPixelMap[i].replaceIndex];
int pilatusDetector::stringEndsWith(const char *aString, const char *aSubstring, int shouldIgnoreCase)
    int i, j;
    i = strlen(aString) - 1;
    j = strlen(aSubstring) - 1;
    while (i >= 0 && j >= 0) {
        if (shouldIgnoreCase) {
            if (tolower(aString[i]) != tolower(aSubstring[j])) return 0;
        } else {
            if (aString[i] != aSubstring[j]) return 0;
        i--; j--;
    return j < 0;
/** This function reads TIFF or CBF image files.  It is not intended to be general, it
 * is intended to read the TIFF or CBF files that camserver creates.  It checks to make
 * sure that the creation time of the file is after a start time passed to it, to force
 * it to wait for a new file to be created.
asynStatus pilatusDetector::readImageFile(const char *fileName, epicsTimeStamp *pStartTime, double timeout, NDArray *pImage)
    const char *functionName = "readImageFile";
    if (stringEndsWith(fileName, ".tif", 1) || stringEndsWith(fileName, ".tiff", 1)) {
        return readTiff(fileName, pStartTime, timeout, pImage);
    } else if (stringEndsWith(fileName, ".cbf", 1)) {
        return readCbf(fileName, pStartTime, timeout, pImage);
    } else {
            "%s::%s, unsupported image file name extension, expected .tif or .cbf, fileName=%s\n",
        setStringParam(ADStatusMessage, "Unsupported file extension, expected .tif or .cbf");
        return(asynError);
/** This function reads CBF files using CBFlib.  It is not intended to be general, it is
/ * intended to read the CBF files that camserver creates.  It checks to make sure that
asynStatus pilatusDetector::readCbf(const char *fileName, epicsTimeStamp *pStartTime, double timeout, NDArray *pImage)
    double deltaTime;
    int status=-1;
    const char *functionName = "readCbf";
    cbf_handle cbf;
    FILE *file=NULL;
    unsigned int cbfCompression;
    int cbfBinaryId;
    size_t cbfElSize;
    int cbfElSigned;
    int cbfElUnsigned;
    size_t cbfElements;
    int cbfMinElement;
    int cbfMaxElement;
    const char *cbfByteOrder;
    size_t cbfDimFast;
    size_t cbfDimMid;
    size_t cbfDimSlow;
    size_t cbfPadding;
    size_t cbfElementsRead;
    deltaTime = 0.;
    status = waitForFileToExist(fileName, pStartTime, timeout, pImage);
    if (status != asynSuccess) {
        return((asynStatus)status);
    cbf_set_warning_messages_enabled(0);
    cbf_set_error_messages_enabled(0);
    printf("%s \n", fileName);
        /* At this point we know the file exists, but it may not be completely
         * written yet.  If we get errors then try again. */
        status = cbf_make_handle(&cbf);
        if (status != 0) {
                "%s::%s, failed to make CBF handle, error code %#x\n",
                driverName, functionName, status);
            return(asynError);
        status = cbf_set_cbf_logfile(cbf, NULL);
        if (status != 0) {
                "%s::%s, failed to disable CBF logging, error code %#x\n",
            return(asynError);
        file = fopen(fileName, "rb");
        if (file == NULL) {
                "%s::%s, failed to open CBF file \"%s\" for reading: %s\n",
                driverName, functionName, fileName, strerror(errno));
            cbf_free_handle(cbf);
            return(asynError);
        status = cbf_read_widefile(cbf, file, MSG_DIGESTNOW);
        if (status != 0) goto retry;
        status = cbf_find_tag(cbf, "_array_data.data");
        /* Do some basic checking that the image size is what we expect */
        status = cbf_get_integerarrayparameters_wdims_fs(cbf, &cbfCompression,
            &cbfBinaryId, &cbfElSize, &cbfElSigned, &cbfElUnsigned,
            &cbfElements, &cbfMinElement, &cbfMaxElement, &cbfByteOrder,
            &cbfDimFast, &cbfDimMid, &cbfDimSlow, &cbfPadding);
        if (cbfDimFast != (size_t)pImage->dims[0].size) {
                "%s::%s, image width incorrect =%zd, should be %d\n",
                driverName, functionName, cbfDimFast, pImage->dims[0].size);
            return(asynError);
        if (cbfDimMid != (size_t)pImage->dims[1].size) {
                "%s::%s, image height incorrect =%zd, should be %d\n",
                driverName, functionName, cbfDimMid, pImage->dims[1].size);
            return(asynError);
        /* Read the image */
        status = cbf_get_integerarray(cbf, &cbfBinaryId, pImage->pData,
            sizeof(epicsInt32), 1, cbfElements, &cbfElementsRead);
        if (cbfElements != cbfElementsRead) goto retry;
        /* Sucesss! */
        status = cbf_free_handle(cbf);
        if (status != 0) {
                "%s::%s, failed to free CBF handle, error code %#x\n",
            return(asynError);
        break;
        retry:
        if (status != 0) {
            return(asynError);
         * acquisition */
            return(asynError);
    correctBadPixels(pImage);
/** This function reads TIFF files using libTiff.  It is not intended to be general,
 * it is intended to read the TIFF files that camserver creates.  It checks to make sure
 * that the creation time of the file is after a start time passed to it, to force it to
 * wait for a new file to be created.
asynStatus pilatusDetector::readTiff(const char *fileName, epicsTimeStamp *pStartTime, double timeout, NDArray *pImage)
    double deltaTime;
    int status=-1;
    const char *functionName = "readTiff";
    int size, totalSize;
    int numStrips, strip;
    char *buffer;
    TIFF *tiff=NULL;
    epicsUInt32 uval;
    deltaTime = 0.;
    /* Suppress error messages from the TIFF library */
    TIFFSetErrorHandler(NULL);
    TIFFSetWarningHandler(NULL);
        /* At this point we know the file exists, but it may not be completely written yet.
         * If we get errors then try again */
        tiff = TIFFOpen(fileName, "rc");
        if (tiff == NULL) {
            status = asynError;
            goto retry;
        status = TIFFGetField(tiff, TIFFTAG_IMAGEWIDTH, &uval);
        if (uval != (epicsUInt32)pImage->dims[0].size) {
                "%s::%s, image width incorrect =%u, should be %d\n",
                driverName, functionName, uval, pImage->dims[0].size);
            goto retry;
        status = TIFFGetField(tiff, TIFFTAG_IMAGELENGTH, &uval);
        if (uval != (epicsUInt32)pImage->dims[1].size) {
                "%s::%s, image length incorrect =%u, should be %d\n",
                driverName, functionName, uval, pImage->dims[1].size);
            goto retry;
        numStrips= TIFFNumberOfStrips(tiff);
        buffer = (char *)pImage->pData;
        totalSize = 0;
        for (strip=0; (strip < numStrips) && (totalSize < pImage->dataSize); strip++) {
            size = TIFFReadEncodedStrip(tiff, 0, buffer, pImage->dataSize-totalSize);
            if (size == -1) {
                /* There was an error reading the file.  Most commonly this is because the file
                 * was not yet completely written.  Try again. */
                asynPrint(this->pasynUserSelf, ASYN_TRACE_FLOW,
                    "%s::%s, error reading TIFF file %s\n",
                goto retry;
            buffer += size;
            totalSize += size;
        if (totalSize != pImage->dataSize) {
            status = asynError;
                "%s::%s, file size incorrect =%d, should be %d\n",
                driverName, functionName, totalSize, pImage->dataSize);
            goto retry;
        /* Sucesss! */
        break;
        retry:
        if (tiff != NULL) TIFFClose(tiff);
        tiff = NULL;
            return(asynError);
asynStatus pilatusDetector::setAcquireParams()
    int ival;
    double dval;
    int triggerMode;
    asynStatus status;
    status = getIntegerParam(ADTriggerMode, &triggerMode);
    if (status != asynSuccess) triggerMode = TMInternal;
     /* When we change modes download all exposure parameters, since some modes
     * replace values with new parameters */
    if (triggerMode == TMAlignment) {
        setIntegerParam(ADNumImages, 1);
    /* nexpf > 1 is only supported in External Enable mode */
    if (triggerMode != TMExternalEnable) {
        setIntegerParam(ADNumExposures, 1);
    status = getIntegerParam(ADNumImages, &ival);
    if ((status != asynSuccess) || (ival < 1)) {
        ival = 1;
        setIntegerParam(ADNumImages, ival);
    epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "nimages %d", ival);
    writeReadCamserver(CAMSERVER_DEFAULT_TIMEOUT);
    status = getIntegerParam(ADNumExposures, &ival);
        ival = 1;
        setIntegerParam(ADNumExposures, ival);
    epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "nexpframe %d", ival);
    status = getDoubleParam(ADAcquireTime, &dval);
    if ((status != asynSuccess) || (dval < 0.)) {
        dval = 1.;
        setDoubleParam(ADAcquireTime, dval);
    epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "exptime %f", dval);
    status = getDoubleParam(ADAcquirePeriod, &dval);
        dval = 2.;
        setDoubleParam(ADAcquirePeriod, dval);
    epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "expperiod %f", dval);
    status = getDoubleParam(PilatusDelayTime, &dval);
        dval = 0.;
        setDoubleParam(PilatusDelayTime, dval);
    epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "delay %f", dval);
    status = getIntegerParam(PilatusGapFill, &ival);
    if ((status != asynSuccess) || (ival < -2) || (ival > 0)) {
        ival = -2;
        setIntegerParam(PilatusGapFill, ival);
    /* -2 is used to indicate that GapFill is not supported because it is a single element detector */
    if (ival != -2) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "gapfill %d", ival);
asynStatus pilatusDetector::setThreshold()
    int igain, status;
    double threshold, dgain;
    getDoubleParam(ADGain, &dgain);
    igain = (int)(dgain + 0.5);
    if (igain < 0) igain = 0;
    if (igain > 3) igain = 3;
    getDoubleParam(PilatusThreshold, &threshold);
    epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "SetThreshold %s %f",
                    gainStrings[igain], threshold*1000.);
    /* Set the status to waiting so we can be notified when it has finished */
    setIntegerParam(ADStatus, ADStatusWaiting);
    setStringParam(ADStatusMessage, "Setting threshold");
    callParamCallbacks();
    status=writeReadCamserver(90.0);  /* This command can take 78 seconds on a 6M */
    if (status)
        setIntegerParam(ADStatus, ADStatusError);
    else
        setIntegerParam(ADStatus, ADStatusIdle);
    setIntegerParam(PilatusThresholdApply, 0);
    /* The SetThreshold command resets numimages to 1 and gapfill to 0, so re-send current
     * acquisition parameters */
    setAcquireParams();
asynStatus pilatusDetector::writeCamserver(double timeout)
    size_t nwrite;
    asynStatus status;
    const char *functionName="writeCamserver";
    /* Flush any stale input, since the next operation is likely to be a read */
    status = pasynOctetSyncIO->flush(this->pasynUserCamserver);
    status = pasynOctetSyncIO->write(this->pasynUserCamserver, this->toCamserver,
                                     strlen(this->toCamserver), timeout,
                                     &nwrite);
    if (status) asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
                    "%s:%s, status=%d, sent\n%s\n",
                    driverName, functionName, status, this->toCamserver);
    /* Set output string so it can get back to EPICS */
    setStringParam(ADStringToServer, this->toCamserver);
    return(status);
asynStatus pilatusDetector::readCamserver(double timeout)
    size_t nread;
    asynStatus status=asynSuccess;
    int eventStatus;
    asynUser *pasynUser = this->pasynUserCamserver;
    int eomReason;
    double deltaTime;
    const char *functionName="readCamserver";
    /* We implement the timeout with a loop so that the port does not
     * block during the entire read.  If we don't do this then it is not possible
     * to abort a long exposure */
    deltaTime = 0;
        status = pasynOctetSyncIO->read(pasynUser, this->fromCamserver,
                                        sizeof(this->fromCamserver), ASYN_POLL_TIME,
                                        &nread, &eomReason);
        if (status != asynTimeout) break;
        eventStatus = epicsEventWaitWithTimeout(this->stopEventId, ASYN_POLL_TIME);
        if (eventStatus == epicsEventWaitOK) {
            return(asynError);
    // If we got asynTimeout, and timeout=0 then this is not an error, it is a poll checking for possible reply and we are done
   if ((status == asynTimeout) && (timeout == 0)) return(asynSuccess);
        asynPrint(pasynUser, ASYN_TRACE_ERROR,
                    "%s:%s, timeout=%f, status=%d received %d bytes\n%s\n",
                    driverName, functionName, timeout, status, nread, this->fromCamserver);
    else {
        /* Look for the string OK in the response */
        if (!strstr(this->fromCamserver, "OK")) {
                      "%s:%s unexpected response from camserver, no OK, response=%s\n",
                      driverName, functionName, this->fromCamserver);
            setStringParam(ADStatusMessage, "Error from camserver");
            status = asynError;
        } else
            setStringParam(ADStatusMessage, "Camserver returned OK");
    setStringParam(ADStringFromServer, this->fromCamserver);
    return(status);
asynStatus pilatusDetector::writeReadCamserver(double timeout)
    asynStatus status;
    status = writeCamserver(timeout);
    if (status) return status;
    status = readCamserver(timeout);
    return status;
static void pilatusTaskC(void *drvPvt)
    pilatusDetector *pPvt = (pilatusDetector *)drvPvt;
    pPvt->pilatusTask();
/** This thread controls acquisition, reads image files to get the image data, and
  * does the callbacks to send it to higher layers */
void pilatusDetector::pilatusTask()
    int status = asynSuccess;
    int imageCounter;
    int numImages;
    int multipleFileNextImage=0;  /* This is the next image number, starting at 0 */
    int acquire;
    ADStatus_t acquiring;
    double startAngle;
    NDArray *pImage;
    double acquireTime, acquirePeriod;
    double readImageFileTimeout, timeout;
    int triggerMode;
    epicsTimeStamp startTime;
    const char *functionName = "pilatusTask";
    char fullFileName[MAX_FILENAME_LEN], fullFileNameTmp[MAX_FILENAME_LEN], fullFileNameConvert[MAX_FILENAME_LEN];
    char filePath[MAX_FILENAME_LEN];
    char statusMessage[MAX_MESSAGE_SIZE];
    int dims[2];
    int arrayCallbacks;
    int flatFieldValid;
    this->lock();
    /* Loop forever */
    while (1) {
        /* Is acquisition active? */
        getIntegerParam(ADAcquire, &acquire);
        /* If we are not acquiring then wait for a semaphore that is given when acquisition is started */
        if (!acquire) {
            /* Only set the status message if we didn't encounter any errors last time, so we don't overwrite the
             error message */
            if (!status)
            setStringParam(ADStatusMessage, "Waiting for acquire command");
            /* Release the lock while we wait for an event that says acquire has started, then lock again */
            this->unlock();
                "%s:%s: waiting for acquire to start\n", driverName, functionName);
            status = epicsEventWait(this->startEventId);
            this->lock();
        /* We are acquiring. */
        /* Get the current time */
        epicsTimeGetCurrent(&startTime);
        /* Get the exposure parameters */
        getDoubleParam(ADAcquireTime, &acquireTime);
        getDoubleParam(ADAcquirePeriod, &acquirePeriod);
        getDoubleParam(PilatusImageFileTmot, &readImageFileTimeout);
        /* Get the acquisition parameters */
        acquiring = ADStatusAcquire;
        setIntegerParam(ADStatus, acquiring);
        /* Reset the MX settings start angle */
        getDoubleParam(PilatusStartAngle, &startAngle);
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Start_angle %f", startAngle);
        /* Create the full filename */
        createFileName(sizeof(fullFileName), fullFileName);
if (numImages > 1) {
int length = strlen(fullFileName);
if (length > 0) {
strcpy(fullFileNameTmp, &fullFileName[8]);
if (fullFileName[0] == '/') {
strcpy(fullFileNameConvert, "/data");
} else {
strcpy(fullFileNameConvert, "/data/");
strcat(fullFileNameConvert, fullFileNameTmp);
        switch (triggerMode) {
            case TMInternal:
                epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "Exposure %s", fullFileName);
                break;
            case TMExternalEnable:
                    "ExtEnable %s", fullFileName);
                break;
            case TMExternalTrigger:
                    "ExtTrigger %s", fullFileName);
                break;
            case TMMultipleExternalTrigger:
                    "ExtMTrigger %s", fullFileName);
                break;
            case TMAlignment:
                getStringParam(NDFilePath, sizeof(filePath), filePath);
                epicsSnprintf(fullFileName, sizeof(fullFileName), "%salignment.tif",
                              filePath);
                break;
        setStringParam(ADStatusMessage, "Starting exposure");
        /* Send the acquire command to camserver and wait for the 15OK response */
        writeReadCamserver(2.0);
        /* Do another read in case there is an ERR string at the end of the input buffer */
        status=readCamserver(0.0);
        /* If the status wasn't asynSuccess or asynTimeout, report the error */
        if (status>1) {
            acquire = 0;
        else {
            /* Set status back to asynSuccess as the timeout was expected */
            /* Open the shutter */
            setShutter(1);
            /* Set the armed flag */
            setIntegerParam(PilatusArmed, 1);
            /* Create the format string for constructing file names for multi-image collection */
            makeMultipleFileFormat(fullFileName);
            makeMultipleFileFormat(fullFileNameConvert);
            multipleFileNextImage = 0;
            /* Call the callbacks to update any changes */
            // setStringParam(NDFullFileName, fullFileName);
            setStringParam(NDFullFileName, fullFileNameConvert);
        while (acquire) {
            if (numImages == 1) {
                /* For single frame or alignment mode need to wait for 7OK response from camserver
                 * saying acquisition is complete before trying to read file, else we get a
                 * recent but stale file. */
                setStringParam(ADStatusMessage, "Waiting for 7OK response");
                /* We release the mutex when waiting for 7OK because this takes a long time and
                 * we need to allow abort operations to get through */
                this->unlock();
                status = readCamserver(acquireTime + readImageFileTimeout);
                this->lock();
                /* If there was an error jump to bottom of loop */
                if (status) {
                    acquire = 0;
                    if(status==asynTimeout)
                      setStringParam(ADStatusMessage, "Timeout waiting for camserver response");
                    continue;
             } else {
                /* If this is a multi-file acquisition the file name is built differently */
                epicsSnprintf(fullFileName, sizeof(fullFileName), multipleFileFormat, multipleFileNumber);
                epicsSnprintf(fullFileNameConvert, sizeof(fullFileNameConvert), multipleFileFormat, multipleFileNumber);
            getIntegerParam(NDArrayCallbacks, &arrayCallbacks);
            if (arrayCallbacks) {
                getIntegerParam(NDArrayCounter, &imageCounter);
                imageCounter++;
                setIntegerParam(NDArrayCounter, imageCounter);
                /* Get an image buffer from the pool */
                getIntegerParam(ADMaxSizeX, &dims[0]);
                getIntegerParam(ADMaxSizeY, &dims[1]);
                pImage = this->pNDArrayPool->alloc(2, dims, NDInt32, 0, NULL);
                epicsSnprintf(statusMessage, sizeof(statusMessage), "Reading image file %s", fullFileNameConvert);
                setStringParam(ADStatusMessage, statusMessage);
                /* We release the mutex when calling readImageFile, because this takes a long time and
                this->unlock();
                status = readImageFile(fullFileNameConvert, &startTime, acquireTime + readImageFileTimeout, pImage);
                this->lock();
                if (status) {
                    acquire = 0;
                    pImage->release();
                    continue;
                getIntegerParam(PilatusFlatFieldValid, &flatFieldValid);
                if (flatFieldValid) {
                    epicsInt32 *pData, *pFlat, i;
                    for (i=0, pData = (epicsInt32 *)pImage->pData, pFlat = (epicsInt32 *)this->pFlatField->pData;
                         i<dims[0]*dims[1];
                         i++, pData++, pFlat++) {
                        *pData = (epicsInt32)((this->averageFlatField * *pData) / *pFlat);
                /* Put the frame number and time stamp into the buffer */
                pImage->uniqueId = imageCounter;
                pImage->timeStamp = startTime.secPastEpoch + startTime.nsec / 1.e9;
                /* Get any attributes that have been defined for this driver */
                this->getAttributes(pImage->pAttributeList);
                this->unlock();
                     "%s:%s: calling NDArray callback\n", driverName, functionName);
                doCallbacksGenericPointer(pImage, NDArrayData, 0);
                this->lock();
                /* Free the image buffer */
                pImage->release();
                } else {
                    acquire = 0;
            } else if (numImages > 1) {
                multipleFileNextImage++;
                multipleFileNumber++;
                multipleFileNumber2++;
                if (multipleFileNextImage == numImages) acquire = 0;
        /* We are done acquiring */
        /* Wait for the 7OK response from camserver in the case of multiple images */
        if ((numImages > 1) && (status == asynSuccess)) {
            /* If arrayCallbacks is 0we will have gone through the above loop without waiting
             * for each image file to be written.  Thus, we may need to wait a long time for
             * the 7OK response.
             * If arrayCallbacks is 1 then the response should arrive fairly soon. */
            if (arrayCallbacks)
                timeout = readImageFileTimeout;
            else
                timeout = numImages * acquireTime + readImageFileTimeout;
            /* We release the mutex because we may wait a long time and need to allow abort
             * operations to get through */
            this->unlock();
            this->lock();
        setShutter(0);
        setIntegerParam(ADAcquire, 0);
        setIntegerParam(PilatusArmed, 0);
        /* If everything was ok, set the status back to idle */
        if (!status)
        else
/** Called when asyn clients call pasynInt32->write().
  * This function performs actions for some parameters, including ADAcquire, ADTriggerMode, etc.
  * For all parameters it sets the value in the parameter library and calls any registered callbacks..
  * \param[in] pasynUser pasynUser structure that encodes the reason and address.
  * \param[in] value Value to write. */
asynStatus pilatusDetector::writeInt32(asynUser *pasynUser, epicsInt32 value)
    int function = pasynUser->reason;
    int adstatus;
    asynStatus status = asynSuccess;
    const char *functionName = "writeInt32";
    status = setIntegerParam(function, value);
    if (function == ADAcquire) {
        getIntegerParam(ADStatus, &adstatus);
        if (value && (adstatus == ADStatusIdle || adstatus == ADStatusError)) {
            /* Send an event to wake up the Pilatus task.  */
            epicsEventSignal(this->startEventId);
        if (!value && (adstatus == ADStatusAcquire)) {
            /* This was a command to stop acquisition */
            epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "Stop");
            epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "K");
            writeCamserver(CAMSERVER_DEFAULT_TIMEOUT);
            epicsEventSignal(this->stopEventId);
    } else if ((function == ADTriggerMode) ||
               (function == ADNumImages) ||
               (function == ADNumExposures) ||
               (function == PilatusGapFill)) {
        setAcquireParams();
    } else if (function == PilatusThresholdApply) {
        setThreshold();
    } else if (function == PilatusNumOscill) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings N_oscillations %d", value);
    } else {
        /* If this parameter belongs to a base class call its method */
        if (function < FIRST_PILATUS_PARAM) status = ADDriver::writeInt32(pasynUser, value);
    /* Do callbacks so higher layers see any changes */
    if (status)
              "%s:%s: error, status=%d function=%d, value=%d\n",
              driverName, functionName, status, function, value);
    else
        asynPrint(pasynUser, ASYN_TRACEIO_DRIVER,
              "%s:%s: function=%d, value=%d\n",
              driverName, functionName, function, value);
    return status;
/** Called when asyn clients call pasynFloat64->write().
  * This function performs actions for some parameters, including ADAcquireTime, ADGain, etc.
asynStatus pilatusDetector::writeFloat64(asynUser *pasynUser, epicsFloat64 value)
    double energyLow, energyHigh;
    double beamX, beamY;
    int thresholdAutoApply;
    const char *functionName = "writeFloat64";
    /* Set the parameter and readback in the parameter library.  This may be overwritten when we read back the
     * status at the end, but that's OK */
    status = setDoubleParam(function, value);
    /* Changing any of the following parameters requires recomputing the base image */
    if ((function == ADGain) ||
        (function == PilatusThreshold)) {
        getIntegerParam(PilatusThresholdAutoApply, &thresholdAutoApply);
        if (thresholdAutoApply)
            setThreshold();
    } else if ((function == ADAcquireTime) ||
               (function == ADAcquirePeriod) ||
               (function == PilatusDelayTime)) {
        setAcquireParams();
    } else if (function == PilatusWavelength) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Wavelength %f", value);
    } else if ((function == PilatusEnergyLow) ||
               (function == PilatusEnergyHigh)) {
        getDoubleParam(PilatusEnergyLow, &energyLow);
        getDoubleParam(PilatusEnergyHigh, &energyHigh);
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Energy_range %f,%f", energyLow, energyHigh);
    } else if (function == PilatusDetDist) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Detector_distance %f", value / 1000.0);
    } else if (function == PilatusDetVOffset) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Detector_Voffset %f", value / 1000.0);
    } else if ((function == PilatusBeamX) ||
               (function == PilatusBeamY)) {
        getDoubleParam(PilatusBeamX, &beamX);
        getDoubleParam(PilatusBeamY, &beamY);
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Beam_xy %f,%f", beamX, beamY);
    } else if (function == PilatusFlux) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Flux %f", value);
    } else if (function == PilatusFilterTransm) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Filter_transmission %f", value);
    } else if (function == PilatusStartAngle) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Start_angle %f", value);
    } else if (function == PilatusAngleIncr) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Angle_increment %f", value);
    } else if (function == PilatusDet2theta) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Detector_2theta %f", value);
    } else if (function == PilatusPolarization) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Polarization %f", value);
    } else if (function == PilatusAlpha) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Alpha %f", value);
    } else if (function == PilatusKappa) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Kappa %f", value);
    } else if (function == PilatusPhi) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Phi %f", value);
    } else if (function == PilatusChi) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Chi %f", value);
    } else {
        if (function < FIRST_PILATUS_PARAM) status = ADDriver::writeFloat64(pasynUser, value);
    if (status)
              "%s:%s error, status=%d function=%d, value=%f\n",
    else
              "%s:%s: function=%d, value=%f\n",
    return status;
/** Called when asyn clients call pasynOctet->write().
  * This function performs actions for some parameters, including PilatusBadPixelFile, ADFilePath, etc.
  * \param[in] value Address of the string to write.
  * \param[in] nChars Number of characters to write.
  * \param[out] nActual Number of characters actually written. */
asynStatus pilatusDetector::writeOctet(asynUser *pasynUser, const char *value,
    const char *functionName = "writeOctet";
    /* Set the parameter in the parameter library. */
    status = (asynStatus)setStringParam(function, (char *)value);
    if (function == PilatusBadPixelFile) {
        this->readBadPixelFile(value);
    } else if (function == PilatusFlatFieldFile) {
        this->readFlatFieldFile(value);
    } else if (function == NDFilePath) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "imgpath %s", value);
        this->checkPath();
    } else if (function == PilatusOscillAxis) {
        epicsSnprintf(this->toCamserver, sizeof(this->toCamserver), "mxsettings Oscillation_axis %s",
            strlen(value) == 0 ? "(nil)" : value);
    } else {
        if (function < FIRST_PILATUS_PARAM) status = ADDriver::writeOctet(pasynUser, value, nChars, nActual);
    status = (asynStatus)callParamCallbacks();
    if (status)
        epicsSnprintf(pasynUser->errorMessage, pasynUser->errorMessageSize,
                  "%s:%s: status=%d, function=%d, value=%s",
    else
              "%s:%s: function=%d, value=%s\n",
    *nActual = nChars;
    return status;
/** Report status of the driver.
  * Prints details about the driver if details>0.
  * It then calls the ADDriver::report() method.
  * \param[in] fp File pointed passed by caller where the output is written to.
  * \param[in] details If >0 then driver details are printed.
void pilatusDetector::report(FILE *fp, int details)
    fprintf(fp, "Pilatus detector %s\n", this->portName);
    if (details > 0) {
        int nx, ny, dataType;
        getIntegerParam(ADSizeX, &nx);
        getIntegerParam(ADSizeY, &ny);
        getIntegerParam(NDDataType, &dataType);
        fprintf(fp, "  NX, NY:            %d  %d\n", nx, ny);
        fprintf(fp, "  Data type:         %d\n", dataType);
    /* Invoke the base class method */
    ADDriver::report(fp, details);
extern "C" int pilatusDetectorConfig(const char *portName, const char *camserverPort,
    new pilatusDetector(portName, camserverPort, maxSizeX, maxSizeY, maxBuffers, maxMemory,
                        priority, stackSize);
/** Constructor for Pilatus driver; most parameters are simply passed to ADDriver::ADDriver.
  * After calling the base class constructor this method creates a thread to collect the detector data,
  * and sets reasonable default values for the parameters defined in this class, asynNDArrayDriver, and ADDriver.
  * \param[in] portName The name of the asyn port driver to be created.
  * \param[in] camserverPort The name of the asyn port previously created with drvAsynIPPortConfigure to
  *            communicate with camserver.
  * \param[in] maxSizeX The size of the Pilatus detector in the X direction.
  * \param[in] maxSizeY The size of the Pilatus detector in the Y direction.
  * \param[in] maxBuffers The maximum number of NDArray buffers that the NDArrayPool for this driver is
  *            allowed to allocate. Set this to -1 to allow an unlimited number of buffers.
  * \param[in] maxMemory The maximum amount of memory that the NDArrayPool for this driver is
  *            allowed to allocate. Set this to -1 to allow an unlimited amount of memory.
  * \param[in] priority The thread priority for the asyn port driver thread if ASYN_CANBLOCK is set in asynFlags.
  * \param[in] stackSize The stack size for the asyn port driver thread if ASYN_CANBLOCK is set in asynFlags.
pilatusDetector::pilatusDetector(const char *portName, const char *camserverPort,
    : ADDriver(portName, 1, NUM_PILATUS_PARAMS, maxBuffers, maxMemory,
               0, 0,             /* No interfaces beyond those set in ADDriver.cpp */
               ASYN_CANBLOCK, 1, /* ASYN_CANBLOCK=1, ASYN_MULTIDEVICE=0, autoConnect=1 */
               priority, stackSize),
      imagesRemaining(0)
    const char *functionName = "pilatusDetector";
    int dims[2];
    /* Create the epicsEvents for signaling to the pilatus task when acquisition starts and stops */
    this->startEventId = epicsEventCreate(epicsEventEmpty);
    if (!this->startEventId) {
        printf("%s:%s epicsEventCreate failure for start event\n",
        return;
    this->stopEventId = epicsEventCreate(epicsEventEmpty);
    if (!this->stopEventId) {
        printf("%s:%s epicsEventCreate failure for stop event\n",
        return;
    /* Allocate the raw buffer we use to read image files.  Only do this once */
    dims[0] = maxSizeX;
    dims[1] = maxSizeY;
    /* Allocate the raw buffer we use for flat fields. */
    this->pFlatField = this->pNDArrayPool->alloc(2, dims, NDUInt32, 0, NULL);
    /* Connect to camserver */
    status = pasynOctetSyncIO->connect(camserverPort, 0, &this->pasynUserCamserver, NULL);
    createParam(PilatusDelayTimeString,      asynParamFloat64, &PilatusDelayTime);
    createParam(PilatusThresholdString,      asynParamFloat64, &PilatusThreshold);
    createParam(PilatusThresholdApplyString, asynParamInt32,   &PilatusThresholdApply);
    createParam(PilatusThresholdAutoApplyString, asynParamInt32,   &PilatusThresholdAutoApply);
    createParam(PilatusArmedString,          asynParamInt32,   &PilatusArmed);
    createParam(PilatusImageFileTmotString,  asynParamFloat64, &PilatusImageFileTmot);
    createParam(PilatusBadPixelFileString,   asynParamOctet,   &PilatusBadPixelFile);
    createParam(PilatusNumBadPixelsString,   asynParamInt32,   &PilatusNumBadPixels);
    createParam(PilatusFlatFieldFileString,  asynParamOctet,   &PilatusFlatFieldFile);
    createParam(PilatusMinFlatFieldString,   asynParamInt32,   &PilatusMinFlatField);
    createParam(PilatusFlatFieldValidString, asynParamInt32,   &PilatusFlatFieldValid);
    createParam(PilatusGapFillString,        asynParamInt32,   &PilatusGapFill);
    createParam(PilatusWavelengthString,     asynParamFloat64, &PilatusWavelength);
    createParam(PilatusEnergyLowString,      asynParamFloat64, &PilatusEnergyLow);
    createParam(PilatusEnergyHighString,     asynParamFloat64, &PilatusEnergyHigh);
    createParam(PilatusDetDistString,        asynParamFloat64, &PilatusDetDist);
    createParam(PilatusDetVOffsetString,     asynParamFloat64, &PilatusDetVOffset);
    createParam(PilatusBeamXString,          asynParamFloat64, &PilatusBeamX);
    createParam(PilatusBeamYString,          asynParamFloat64, &PilatusBeamY);
    createParam(PilatusFluxString,           asynParamFloat64, &PilatusFlux);
    createParam(PilatusFilterTransmString,   asynParamFloat64, &PilatusFilterTransm);
    createParam(PilatusStartAngleString,     asynParamFloat64, &PilatusStartAngle);
    createParam(PilatusAngleIncrString,      asynParamFloat64, &PilatusAngleIncr);
    createParam(PilatusDet2thetaString,      asynParamFloat64, &PilatusDet2theta);
    createParam(PilatusPolarizationString,   asynParamFloat64, &PilatusPolarization);
    createParam(PilatusAlphaString,          asynParamFloat64, &PilatusAlpha);
    createParam(PilatusKappaString,          asynParamFloat64, &PilatusKappa);
    createParam(PilatusPhiString,            asynParamFloat64, &PilatusPhi);
    createParam(PilatusChiString,            asynParamFloat64, &PilatusChi);
    createParam(PilatusOscillAxisString,     asynParamOctet,   &PilatusOscillAxis);
    createParam(PilatusNumOscillString,      asynParamInt32,   &PilatusNumOscill);
    /* Set some default values for parameters */
    status =  setStringParam (ADManufacturer, "Dectris");
    status |= setStringParam (ADModel, "Pilatus");
    status |= setIntegerParam(ADMaxSizeX, maxSizeX);
    status |= setIntegerParam(ADMaxSizeY, maxSizeY);
    status |= setIntegerParam(ADSizeX, maxSizeX);
    status |= setIntegerParam(ADSizeY, maxSizeY);
    status |= setIntegerParam(NDArraySizeX, maxSizeX);
    status |= setIntegerParam(NDArraySizeY, maxSizeY);
    status |= setIntegerParam(NDArraySize, 0);
    status |= setIntegerParam(NDDataType,  NDUInt32);
    status |= setIntegerParam(ADImageMode, ADImageContinuous);
    status |= setIntegerParam(ADTriggerMode, TMInternal);
    status |= setIntegerParam(PilatusArmed, 0);
    status |= setStringParam (PilatusBadPixelFile, "");
    status |= setIntegerParam(PilatusNumBadPixels, 0);
    status |= setStringParam (PilatusFlatFieldFile, "");
    status |= setIntegerParam(PilatusFlatFieldValid, 0);
    if (status) {
        printf("%s: unable to set camera parameters\n", functionName);
        return;
    /* Create the thread that updates the images */
    status = (epicsThreadCreate("PilatusDetTask",
                                epicsThreadPriorityMedium,
                                epicsThreadGetStackSize(epicsThreadStackMedium),
                                (EPICSTHREADFUNC)pilatusTaskC,
                                this) == NULL);
    if (status) {
        printf("%s:%s epicsThreadCreate failure for image task\n",
        return;
/* Code for iocsh registration */
static const iocshArg pilatusDetectorConfigArg0 = {"Port name", iocshArgString};
static const iocshArg pilatusDetectorConfigArg1 = {"camserver port name", iocshArgString};
static const iocshArg pilatusDetectorConfigArg2 = {"maxSizeX", iocshArgInt};
static const iocshArg pilatusDetectorConfigArg3 = {"maxSizeY", iocshArgInt};
static const iocshArg pilatusDetectorConfigArg4 = {"maxBuffers", iocshArgInt};
static const iocshArg pilatusDetectorConfigArg5 = {"maxMemory", iocshArgInt};
static const iocshArg pilatusDetectorConfigArg6 = {"priority", iocshArgInt};
static const iocshArg pilatusDetectorConfigArg7 = {"stackSize", iocshArgInt};
static const iocshArg * const pilatusDetectorConfigArgs[] =  {&pilatusDetectorConfigArg0,
                                                              &pilatusDetectorConfigArg1,
                                                              &pilatusDetectorConfigArg2,
                                                              &pilatusDetectorConfigArg3,
                                                              &pilatusDetectorConfigArg4,
                                                              &pilatusDetectorConfigArg5,
                                                              &pilatusDetectorConfigArg6,
                                                              &pilatusDetectorConfigArg7};
static const iocshFuncDef configPilatusDetector = {"pilatusDetectorConfig", 8, pilatusDetectorConfigArgs};
static void configPilatusDetectorCallFunc(const iocshArgBuf *args)
    pilatusDetectorConfig(args[0].sval, args[1].sval, args[2].ival,  args[3].ival,
                          args[4].ival, args[5].ival, args[6].ival,  args[7].ival);
static void pilatusDetectorRegister(void)
    iocshRegister(&configPilatusDetector, configPilatusDetectorCallFunc);
extern "C" {
epicsExportRegistrar(pilatusDetectorRegister);
this is error message in pilatus ioc
CAS: Client accept error was "Too many open files"
/data/users/kha/BL5C-2016MAR29/230C_2_00001.cbf
2016/03/29 15:02:40.457 pilatusDetector::readCbf, failed to open CBF file "/data/users/kha/BL5C-2016MAR29/230C_2_00001.cbf" for reading: Too many open files
2016/03/29 15:45:22.164 pilatusDetector:readCamserver, timeout=1.000000, status=1 received 0 bytes
When the first operation some time while the file is Not recently been updated.
How can i slove this problem?
thank for Reading
Best Regards
mujin
About Pilatus IOC Error Messgae.. mujin park
Prev: About Pilatus IOC Error Messgae.. mujin park
Next: RE: Question about the connection refused Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: TwinCAT-EPICS IOC tcioc [SEC=UNCLASSIFIED] K*, Shaun
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
