1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: IOC is not operational
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 24 Mar 2016 09:56:36 +0100
Hi Sungsu,
In the drvAsyn... calls, you have to either user quotes around the string arguments, or remove all spaces at the beginning and end.
The error message shows that asyn is trying to interpret the beginning of the URI (a space character) as the protocol tag, which fails.
However, setting the environment variables earlier on seems to suggest using these variable in the calls, so something along the lines of
    drvAsynIPPortConfigure("P1", "$(TCP1)", 0, 0, 0)
seems more appropriate.
Hope this helps,
~Ralph
On 24/03/2016 09:35, [email protected] wrote:
Dear.EPICS friend
I want to control the power supply but medm not operational. Would you some please help me?
Whant part is some problems?
    localhost.localdomain[341]# ./start_run
    #!../../bin/linux-x86_64/ODA_PS_RS232
    ##You may have to change ASYN to something else
    ##everywhere it appears in this file
    < envPaths
    epicsEnvSet("ARCH","linux-x86_64")
    epicsEnvSet("IOC","iocODA_PS_RS232")
    epicsEnvSet("TOP","/home/cha/ODA_PS_RS232")
    epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
    epicsEnvSet("ASYN","/usr/local/epics/extensions/src/synApps_5_7/support/asyn-4-21")
    epicsEnvSet("STREAM","/usr/local/epics/extensions/src/synApps_5_7/support/stream-2-6")
    epicsEnvSet "STREAM_PROTOCOL_PATH" "/home/cha/ODA_PS_RS232/db"
    #Allow PV name prefixes and serial port name to be set from the environment
    epicsEnvSet "P" "10MeV"
    epicsEnvSet "R" "TM"
    epicsEnvSet "TCP1" "100.100.10.13:4001"
    epicsEnvSet "TCP2" "100.100.10.14:4002"
    epicsEnvSet "TCP3" "100.100.10.15:4003"
    epicsEnvSet "TCP4" "100.100.10.11:4004"
    epicsEnvSet "TCP5" "100.100.10.11:4005"
- Ignored:
    epicsEnvSet "TCP6" "100.100.10.11:4006"
    epicsEnvSet "TCP7" "100.100.10.11:4007"
    epicsEnvSet "TCP8" "100.100.10.11:4008"
    cd /home/cha/ODA_PS_RS232
    ##Register all support components
    dbLoadDatabase "dbd/ODA_PS_RS232.dbd"
    ODA_PS_RS232_registerRecordDeviceDriver pdbbase
    #The ASYN ports below are for the first terminal server with numerical
    #instantiation for TCP macros.
    #Note if new power supply added a new entry will have to be made here.
    #If any additions are made, one should instantiate differently.
    #Instead of  P1, P2, ...  one should use something like  L1, L2, ... .
    #drvAsynIPPortConfigure( portName , hostInfo ,priority,noAutoConnect,noProcessEos)
    drvAsynIPPortConfigure( P1 , 100.100.10.13:4001 ,0,0,0)
    drvAsynIPPortConfigure: Unknown protocol " ".
    drvAsynIPPortConfigure( P2 , 100.100.10.14:4002 ,0,0,0)
    drvAsynIPPortConfigure( P3 , 100.100.10.15:4003 ,0,0,0)
    drvAsynIPPortConfigure( P4 , 100.100.10.11:4004 ,0,0,0)
    drvAsynIPPortConfigure( P5 , 100.100.10.11:4005 ,0,0,0)
    drvAsynIPPortConfigure( P6 , 100.100.10.11:4006 ,0,0,0)
    drvAsynIPPortConfigure( P7 , 100.100.10.11:4007 ,0,0,0)
    drvAsynIPPortConfigure( P8 , 100.100.10.11:4008 ,0,0,0)
    ##The lines below are for debugging purposes.
    #If additions made to drvAsynIPPortConfigure entries,
    #then copy lines 2 lines below and use new letter
    #that you made in new drvAsynIPPortConfigure.
    #See comments starting on line 61.
    asynSetTraceIOMask( P1 ,-1,0x2)
    asynManager:connectDevice port  P1  not found
    asynSetTraceMask( P1 ,-1,0x9)
    asynSetTraceIOMask( P2 ,-1,0x2)
    asynManager:connectDevice port  P2  not found
    asynSetTraceMask( P2 ,-1,0x9)
    asynSetTraceIOMask( P3 ,-1,0x2)
    asynManager:connectDevice port  P3  not found
    asynSetTraceMask( P3 ,-1,0x9)
    asynSetTraceIOMask( P4 ,-1,0x2)
    asynManager:connectDevice port  P4  not found
    asynSetTraceMask( P4 ,-1,0x9)
    asynSetTraceIOMask( P5 ,-1,0x2)
    asynManager:connectDevice port  P5  not found
    asynSetTraceMask( P5 ,-1,0x9)
    asynSetTraceIOMask( P6 ,-1,0x2)
    asynManager:connectDevice port  P6  not found
    asynSetTraceMask( P6 ,-1,0x9)
    asynSetTraceIOMask( P7 ,-1,0x2)
    asynManager:connectDevice port  P7  not found
    asynSetTraceMask( P7 ,-1,0x9)
    asynSetTraceIOMask( P8 ,-1,0x2)
    asynManager:connectDevice port  P8  not found
    asynSetTraceMask( P8 ,-1,0x9)
    ###Load record instances
    #Note: if new TDK-Lambda ZUP power supplies become available:
    # 1.) Add a new macro to account for new port. See comments in beginning around line 12.
    # 2.) Add a new  drvAsynIPPortConfigure . See comments starting on line 59.
    # 3.) Add a couple new debugging lines. See comments on line 101.
    # 4.) Add a new dbLoadRecords line with with a new  PORT  line and  A  line.
    #The  PORT  and  A  come from database files. One can just as easily label the port
    # PORTA  or  PORTA1 , as long as it s the same as the database file.
    ### 10 MeV Linac #############
    # Solenoids & Steerings
    dbLoadRecords( db/10MeV_ODA_PS_RS232_1.db , P=10MeV,R=TM1:,PORT1=P1,A=1 )
    filename="../dbLexRoutines.c" line number=240
    No such file or directory dbRead opening file  db/10MeV_ODA_PS_RS232_1.db
    dbLoadRecords( db/10MeV_ODA_PS_RS232_2.db , P=10MeV,R=TM2:,PORT2=P2,A=2 )
    No such file or directory dbRead opening file  db/10MeV_ODA_PS_RS232_2.db
    dbLoadRecords( db/10MeV_ODA_PS_RS232_3.db , P=10MeV,R=TM3:,PORT3=P3,A=3 )
    No such file or directory dbRead opening file  db/10MeV_ODA_PS_RS232_3.db
    dbLoadRecords( db/10MeV_ODA_PS_RS232_4.db , P=10MeV,R=TM4:,PORT4=P4,A=4 )
    No such file or directory dbRead opening file  db/10MeV_ODA_PS_RS232_4.db
    dbLoadRecords( db/10MeV_ODA_PS_RS232_5.db , P=10MeV,R=TM5:,PORT5=P5,A=5 )
    No such file or directory dbRead opening file  db/10MeV_ODA_PS_RS232_5.db
    dbLoadRecords( db/10MeV_ODA_PS_RS232_6.db , P=10MeV,R=TM6:,PORT6=P6,A=6 )
    No such file or directory dbRead opening file  db/10MeV_ODA_PS_RS232_6.db
    dbLoadRecords( db/10MeV_ODA_PS_RS232_7.db , P=10MeV,R=TM7:,PORT7=P7,A=7 )
    No such file or directory dbRead opening file  db/10MeV_ODA_PS_RS232_7.db
    dbLoadRecords( db/10MeV_ODA_PS_RS232_8.db , P=10MeV,R=TM8:,PORT8=P8,A=8 )
    No such file or directory dbRead opening file  db/10MeV_ODA_PS_RS232_8.db
    #dbLoadRecords("db/xxx.db","user=chaHost")
    cd /home/cha/ODA_PS_RS232/iocBoot/iocODA_PS_RS232
    iocInit
    Starting iocInit
    ## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$
    ## EPICS Base built Dec 23 2015
    MEDM Version 3.1.8.1: Loading aliased fonts.................
    iocRun: All initialization complete
    ## Start any sequence programs
    #seq sncxxx,"user=chaHost"
    ../online_notify.c: CA beacon (send to "100.100.10.255:5065") error was "Connection refused"
    epics> ../online_notify.c: CA beacon (send to "100.100.10.255:5065") error was "Connection refused"
    SIGINT
    ^C
    which part is problems??
    Please, help me
    Thanks
    Sungsu
MEDM is not operational [email protected]
Prev: MEDM is not operational [email protected]
Next: Hotel reservations for Spring EPICS meeting Timo Korhonen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: Re: MEDM/IOC is not operational Pete Jemian
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
