Dear.EPICS friend
I want to control the power supply but medm not operational. Would you some please help me?
Whant part is some problems?
localhost.localdomain[341]# ./start_run
#!../../bin/linux-x86_64/ODA_PS_RS232
##You may have to change ASYN to something else
##everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocODA_PS_RS232")
epicsEnvSet("TOP","/home/cha/ODA_PS_RS232")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
epicsEnvSet("ASYN","/usr/local/epics/extensions/src/synApps_5_7/support/asyn-4-21")
epicsEnvSet("STREAM","/usr/local/epics/extensions/src/synApps_5_7/support/stream-2-6")
epicsEnvSet "STREAM_PROTOCOL_PATH" "/home/cha/ODA_PS_RS232/db"
#Allow PV name prefixes and serial port name to be set from the environment
epicsEnvSet "P" "10MeV"
epicsEnvSet "R" "TM"
epicsEnvSet "TCP1" "100.100.10.13:4001"
epicsEnvSet "TCP2" "100.100.10.14:4002"
epicsEnvSet "TCP3" "100.100.10.15:4003"
epicsEnvSet "TCP4" "100.100.10.11:4004"
epicsEnvSet "TCP5" "100.100.10.11:4005"
- Ignored:
epicsEnvSet "TCP6" "100.100.10.11:4006"
epicsEnvSet "TCP7" "100.100.10.11:4007"
epicsEnvSet "TCP8" "100.100.10.11:4008"
cd /home/cha/ODA_PS_RS232
##Register all support components
dbLoadDatabase "dbd/ODA_PS_RS232.dbd"
ODA_PS_RS232_registerRecordDeviceDriver pdbbase
#The ASYN ports below are for the first terminal server with numerical
#instantiation for TCP macros.
#Note if new power supply added a new entry will have to be made here.
#If any additions are made, one should instantiate differently.
#Instead of P1, P2, ... one should use something like L1, L2, ... .
#drvAsynIPPortConfigure( portName , hostInfo ,priority,noAutoConnect,noProcessEos)
drvAsynIPPortConfigure( P1 , 100.100.10.13:4001 ,0,0,0)
drvAsynIPPortConfigure: Unknown protocol " ".
drvAsynIPPortConfigure( P2 , 100.100.10.14:4002 ,0,0,0)
drvAsynIPPortConfigure( P3 , 100.100.10.15:4003 ,0,0,0)
drvAsynIPPortConfigure( P4 , 100.100.10.11:4004 ,0,0,0)
drvAsynIPPortConfigure( P5 , 100.100.10.11:4005 ,0,0,0)
drvAsynIPPortConfigure( P6 , 100.100.10.11:4006 ,0,0,0)
drvAsynIPPortConfigure( P7 , 100.100.10.11:4007 ,0,0,0)
drvAsynIPPortConfigure( P8 , 100.100.10.11:4008 ,0,0,0)
##The lines below are for debugging purposes.
#If additions made to drvAsynIPPortConfigure entries,
#then copy lines 2 lines below and use new letter
#that you made in new drvAsynIPPortConfigure.
#See comments starting on line 61.
asynSetTraceIOMask( P1 ,-1,0x2)
asynManager:connectDevice port P1 not found
asynSetTraceMask( P1 ,-1,0x9)
asynSetTraceIOMask( P2 ,-1,0x2)
asynManager:connectDevice port P2 not found
asynSetTraceMask( P2 ,-1,0x9)
asynSetTraceIOMask( P3 ,-1,0x2)
asynManager:connectDevice port P3 not found
asynSetTraceMask( P3 ,-1,0x9)
asynSetTraceIOMask( P4 ,-1,0x2)
asynManager:connectDevice port P4 not found
asynSetTraceMask( P4 ,-1,0x9)
asynSetTraceIOMask( P5 ,-1,0x2)
asynManager:connectDevice port P5 not found
asynSetTraceMask( P5 ,-1,0x9)
asynSetTraceIOMask( P6 ,-1,0x2)
asynManager:connectDevice port P6 not found
asynSetTraceMask( P6 ,-1,0x9)
asynSetTraceIOMask( P7 ,-1,0x2)
asynManager:connectDevice port P7 not found
asynSetTraceMask( P7 ,-1,0x9)
asynSetTraceIOMask( P8 ,-1,0x2)
asynManager:connectDevice port P8 not found
asynSetTraceMask( P8 ,-1,0x9)
###Load record instances
#Note: if new TDK-Lambda ZUP power supplies become available:
# 1.) Add a new macro to account for new port. See comments in beginning around line 12.
# 2.) Add a new drvAsynIPPortConfigure . See comments starting on line 59.
# 3.) Add a couple new debugging lines. See comments on line 101.
# 4.) Add a new dbLoadRecords line with with a new PORT line and A line.
#The PORT and A come from database files. One can just as easily label the port
# PORTA or PORTA1 , as long as it s the same as the database file.
### 10 MeV Linac #############
# Solenoids & Steerings
dbLoadRecords( db/10MeV_ODA_PS_RS232_1.db , P=10MeV,R=TM1:,PORT1=P1,A=1 )
filename="../dbLexRoutines.c" line number=240
No such file or directory dbRead opening file db/10MeV_ODA_PS_RS232_1.db
dbLoadRecords( db/10MeV_ODA_PS_RS232_2.db , P=10MeV,R=TM2:,PORT2=P2,A=2 )
No such file or directory dbRead opening file db/10MeV_ODA_PS_RS232_2.db
dbLoadRecords( db/10MeV_ODA_PS_RS232_3.db , P=10MeV,R=TM3:,PORT3=P3,A=3 )
No such file or directory dbRead opening file db/10MeV_ODA_PS_RS232_3.db
dbLoadRecords( db/10MeV_ODA_PS_RS232_4.db , P=10MeV,R=TM4:,PORT4=P4,A=4 )
No such file or directory dbRead opening file db/10MeV_ODA_PS_RS232_4.db
dbLoadRecords( db/10MeV_ODA_PS_RS232_5.db , P=10MeV,R=TM5:,PORT5=P5,A=5 )
No such file or directory dbRead opening file db/10MeV_ODA_PS_RS232_5.db
dbLoadRecords( db/10MeV_ODA_PS_RS232_6.db , P=10MeV,R=TM6:,PORT6=P6,A=6 )
No such file or directory dbRead opening file db/10MeV_ODA_PS_RS232_6.db
dbLoadRecords( db/10MeV_ODA_PS_RS232_7.db , P=10MeV,R=TM7:,PORT7=P7,A=7 )
No such file or directory dbRead opening file db/10MeV_ODA_PS_RS232_7.db
dbLoadRecords( db/10MeV_ODA_PS_RS232_8.db , P=10MeV,R=TM8:,PORT8=P8,A=8 )
No such file or directory dbRead opening file db/10MeV_ODA_PS_RS232_8.db
#dbLoadRecords("db/xxx.db","user=chaHost")
cd /home/cha/ODA_PS_RS232/iocBoot/iocODA_PS_RS232
iocInit
Starting iocInit
## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$
## EPICS Base built Dec 23 2015
MEDM Version 3.1.8.1: Loading aliased fonts.................
## Start any sequence programs
#seq sncxxx,"user=chaHost"
../online_notify.c: CA beacon (send to "100.100.10.255:5065") error was "Connection refused"
epics> ../online_notify.c: CA beacon (send to "100.100.10.255:5065") error was "Connection refused"
SIGINT
^C
which part is problems??
Please, help me
Thanks
Sungsu
