1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: generic CSS version
To: "Kasemir, Kay" <[email protected]>
Date: Thu, 17 Mar 2016 14:23:46 +0100
Hey all,
last week I was on a conference, so I could not generate the stack trace of CSS.
On 03/03/2016 02:47 PM, Kasemir, Kay wrote:
Hi:
On Mar 3, 2016, at 8:16 AM, Florian Feldbauer <[email protected]> wrote:
On my Laptop I'm using Fedora 20. Here CSS has to be started three times…
Anything more specific available on the source of the error?
workspace/.metadata/.log,
console output,
or JRE hs_err_pid*.log?
As Michael mentioned, there have been several GTK related issues, so if the error includes *_gtk_* then that’s what you’re experiencing.
Good news is that there’s usually some workaround like disabling certain GTK features.
On a different PC with Fedora 20 (recently updated to Fedora 23) CSS works fine.
In the Lab we are using Debian 8. On this machine CSS hangs when opening an OPI file.
If you send the ‘QUIT’ signal
  kill -QUIT {pid of your process}
the JRE creates a stack trace on the console. Look for the main thread to see where it’s hung.
One reason can be missing DNS support, which causes the Channel Access client lib. to hang. It’s trying to resolve the name of the IOC’s IP address so that it can later provide you with nice error messages when the channel disconnects. The fix is to enable DNS or list all IP addresses in /etc/hosts.
I produced the stack trace by using `kill -QUIT`.
But since I'm not familiar with Java or eclipse, I cannot make anything out of it. The stack trace is attached...
I actually don't think, that the problem is related to naming resolutions, since the BEAUTY archiver (using the same Eclipse/Java/CSS base) is running without any problems on the same machine...
Therefore I guess it is related to the GTK bugs mentioned by you and the others.
Also I got a CSS4 package from Carla Tschentscher which is running without any problems.
Best regards,
Florian
For PANDA a simple CSS product coming with BOY and the databrowser would be sufficient for now.
Is there a ready to run version available for CSS 4?
SNS still builds the “basic epics” version of CSS in addition to our site-specific stuff.
Kay
| Dr. Florian Feldbauer                |
| Helmholtz-Institut Mainz /           |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 36         |
| D-55128 Mainz                        |
| Office: SB1 / 00-213                 |
| Phone:  (+49)6131 / 39-29605         |
Full thread dump OpenJDK 64-Bit Server VM (24.95-b01 mixed mode):
"Thread-4" prio=10 tid=0x00007f611091d000 nid=0x1104 in Object.wait() [0x00007f60f8901000]
   java.lang.Thread.State: WAITING (on object monitor)
	at java.lang.Object.wait(Native Method)
	- waiting on <0x0000000785cdbb68> (a org.eclipse.swt.widgets.RunnableLock)
	at java.lang.Object.wait(Object.java:503)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:187)
	- locked <0x0000000785cdbb68> (a org.eclipse.swt.widgets.RunnableLock)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4330)
	at org.eclipse.ui.internal.StartupThreading.runWithThrowable(StartupThreading.java:85)
	at org.eclipse.ui.internal.EditorManager.restoreState(EditorManager.java:967)
	at org.eclipse.ui.internal.WorkbenchPage.restoreState(WorkbenchPage.java:3256)
	at org.eclipse.ui.internal.WorkbenchWindow.restoreState(WorkbenchWindow.java:2232)
	at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.java:3687)
	at org.eclipse.ui.internal.Workbench.access$32(Workbench.java:3629)
	at org.eclipse.ui.internal.Workbench$60.run(Workbench.java:2329)
	at org.eclipse.ui.internal.Workbench.runStartupWithProgress(Workbench.java:2026)
	at org.eclipse.ui.internal.Workbench.restoreState(Workbench.java:2327)
	at org.eclipse.ui.internal.Workbench.access$30(Workbench.java:2298)
	at org.eclipse.ui.internal.Workbench$54.run(Workbench.java:2144)
	at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
	at org.eclipse.ui.internal.Workbench.restoreState(Workbench.java:2088)
	at org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(WorkbenchConfigurer.java:183)
	at org.eclipse.ui.application.WorkbenchAdvisor$1.run(WorkbenchAdvisor.java:781)
"ActiveMQ Task" daemon prio=10 tid=0x00007f608808b000 nid=0x1102 in Object.wait() [0x00007f60f84ad000]
   java.lang.Thread.State: TIMED_WAITING (on object monitor)
	- waiting on <0x00000007d931e780> (a java.lang.Object)
	at org.apache.activemq.transport.failover.FailoverTransport.doReconnect(FailoverTransport.java:939)
	- locked <0x00000007d931e780> (a java.lang.Object)
	at org.apache.activemq.transport.failover.FailoverTransport$2.iterate(FailoverTransport.java:135)
	- locked <0x00000007d931e770> (a java.lang.Object)
	at org.apache.activemq.thread.PooledTaskRunner.runTask(PooledTaskRunner.java:122)
	at org.apache.activemq.thread.PooledTaskRunner$1.run(PooledTaskRunner.java:43)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
	at java.lang.Thread.run(Thread.java:745)
"ActiveMQConnection[ID:palumaLab1-42699-1458133163202-0:1] Scheduler" daemon prio=10 tid=0x00007f608808e000 nid=0x1101 in Object.wait() [0x00007f60f85ae000]
	- waiting on <0x0000000785d27e68> (a java.util.TaskQueue)
	at java.util.TimerThread.mainLoop(Timer.java:526)
	- locked <0x0000000785d27e68> (a java.util.TaskQueue)
	at java.util.TimerThread.run(Timer.java:505)
"Thread-2" prio=10 tid=0x00007f611057c000 nid=0x1100 in Object.wait() [0x00007f60f8a03000]
	- waiting on <0x0000000785d85150> (a org.eclipse.swt.widgets.RunnableLock)
	- locked <0x0000000785d85150> (a org.eclipse.swt.widgets.RunnableLock)
	at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:94)
	at org.eclipse.ui.internal.Workbench.init(Workbench.java:1595)
	at org.eclipse.ui.internal.Workbench.access$36(Workbench.java:1486)
	at org.eclipse.ui.internal.Workbench$66.run(Workbench.java:2597)
"Worker-1" prio=10 tid=0x00007f6094006800 nid=0x10ff in Object.wait() [0x00007f60f8c1b000]
	- waiting on <0x0000000785bd9708> (a org.eclipse.core.internal.jobs.WorkerPool)
	at org.eclipse.core.internal.jobs.WorkerPool.sleep(WorkerPool.java:188)
	- locked <0x0000000785bd9708> (a org.eclipse.core.internal.jobs.WorkerPool)
	at org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPool.java:220)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:50)
"JMSWriteThread" daemon prio=10 tid=0x00007f61107e1800 nid=0x10fe in Object.wait() [0x00007f60f8d25000]
	- waiting on <0x00000007d931e760> (a java.lang.Object)
	at org.apache.activemq.transport.failover.FailoverTransport.oneway(FailoverTransport.java:511)
	- locked <0x00000007d931e760> (a java.lang.Object)
	at org.apache.activemq.transport.MutexTransport.oneway(MutexTransport.java:40)
	- locked <0x0000000785d3d6b0> (a java.lang.Object)
	at org.apache.activemq.transport.ResponseCorrelator.asyncRequest(ResponseCorrelator.java:81)
	at org.apache.activemq.transport.ResponseCorrelator.request(ResponseCorrelator.java:86)
	at org.apache.activemq.ActiveMQConnection.syncSendPacket(ActiveMQConnection.java:1276)
	at org.apache.activemq.ActiveMQConnection.ensureConnectionInfoSent(ActiveMQConnection.java:1384)
	- locked <0x0000000785d3e310> (a java.lang.Object)
	at org.apache.activemq.ActiveMQConnection.start(ActiveMQConnection.java:504)
	at org.csstudio.logging.JMSLogWriter.connect(JMSLogWriter.java:182)
	at org.csstudio.logging.JMSLogWriter.access$1(JMSLogWriter.java:170)
	at org.csstudio.logging.JMSLogWriter$1.run(JMSLogWriter.java:124)
"Worker-0" prio=10 tid=0x00007f6110742800 nid=0x10fd in Object.wait() [0x00007f60f8e26000]
"[ThreadPool Manager] - Idle Thread" daemon prio=10 tid=0x00007f60a054c000 nid=0x10fc in Object.wait() [0x00007f60f9845000]
	- waiting on <0x00000007d95bc090> (a org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor)
	at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:106)
	- locked <0x00000007d95bc090> (a org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor)
"[Timer] - Main Queue Handler" daemon prio=10 tid=0x00007f60a033d800 nid=0x10fb in Object.wait() [0x00007f60f9946000]
	- waiting on <0x00000007d95bcd20> (a java.lang.Object)
	at org.eclipse.equinox.internal.util.impl.tpt.timer.TimerImpl.run(TimerImpl.java:141)
	- locked <0x00000007d95bcd20> (a java.lang.Object)
"Worker-JM" prio=10 tid=0x00007f60a0058800 nid=0x10fa in Object.wait() [0x00007f60f9ab2000]
	- waiting on <0x0000000785be5a70> (a java.util.ArrayList)
	at org.eclipse.core.internal.jobs.InternalWorker.run(InternalWorker.java:58)
	- locked <0x0000000785be5a70> (a java.util.ArrayList)
"Framework Event Dispatcher" daemon prio=10 tid=0x00007f60a001c000 nid=0x10f9 in Object.wait() [0x00007f60f9bb3000]
	- waiting on <0x0000000785bcb8d8> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.getNextEvent(EventManager.java:400)
	- locked <0x0000000785bcb8d8> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:336)
"Start Level Event Dispatcher" daemon prio=10 tid=0x00007f61108a0000 nid=0x10f8 in Object.wait() [0x00007f60f9cb4000]
	- waiting on <0x00000007d948b260> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
	- locked <0x00000007d948b260> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
"Bundle File Closer" daemon prio=10 tid=0x00007f6110871000 nid=0x10f7 in Object.wait() [0x00007f60f9e6c000]
	- waiting on <0x0000000785d28e38> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
	- locked <0x0000000785d28e38> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
"Framework Active Thread" prio=10 tid=0x00007f61103f3800 nid=0x10f6 in Object.wait() [0x00007f610010d000]
	- waiting on <0x00000007d9305388> (a org.eclipse.osgi.framework.internal.core.Framework)
	at org.eclipse.osgi.framework.internal.core.Framework.run(Framework.java:1817)
	- locked <0x00000007d9305388> (a org.eclipse.osgi.framework.internal.core.Framework)
"Service Thread" daemon prio=10 tid=0x00007f61101fe800 nid=0x10f3 runnable [0x0000000000000000]
   java.lang.Thread.State: RUNNABLE
"C2 CompilerThread1" daemon prio=10 tid=0x00007f61101fc000 nid=0x10f2 waiting on condition [0x0000000000000000]
"C2 CompilerThread0" daemon prio=10 tid=0x00007f61101f9000 nid=0x10f1 waiting on condition [0x0000000000000000]
"Signal Dispatcher" daemon prio=10 tid=0x00007f61101f7000 nid=0x10f0 waiting on condition [0x0000000000000000]
"Finalizer" daemon prio=10 tid=0x00007f61101cc000 nid=0x10ef in Object.wait() [0x00007f6109677000]
	- waiting on <0x0000000785c2e920> (a java.lang.ref.ReferenceQueue$Lock)
	at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:135)
	- locked <0x0000000785c2e920> (a java.lang.ref.ReferenceQueue$Lock)
	at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:151)
	at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:209)
"Reference Handler" daemon prio=10 tid=0x00007f61101ca000 nid=0x10ee in Object.wait() [0x00007f6109778000]
	- waiting on <0x0000000785c987e0> (a java.lang.ref.Reference$Lock)
	at java.lang.ref.Reference$ReferenceHandler.run(Reference.java:133)
	- locked <0x0000000785c987e0> (a java.lang.ref.Reference$Lock)
"main" prio=10 tid=0x00007f611000a000 nid=0x10e4 runnable [0x00007f6116eb1000]
	at org.eclipse.swt.internal.gtk.OS._gtk_enumerate_printers(Native Method)
	at org.eclipse.swt.internal.gtk.OS.gtk_enumerate_printers(OS.java:9324)
	at org.eclipse.swt.printing.Printer.getPrinterList(Printer.java:98)
	at org.csstudio.opibuilder.actions.PrintDisplayAction.<init>(PrintDisplayAction.java:48)
	at org.csstudio.opibuilder.util.SingleSourceHelperImpl.iRegisterRCPRuntimeActions(SingleSourceHelperImpl.java:115)
	at org.csstudio.opibuilder.util.SingleSourceHelper.registerRCPRuntimeActions(SingleSourceHelper.java:67)
	at org.csstudio.opibuilder.runmode.OPIRuntimeDelegate.init(OPIRuntimeDelegate.java:168)
	at org.csstudio.opibuilder.runmode.OPIRunner.init(OPIRunner.java:57)
	at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:828)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:271)
	at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1459)
	at org.eclipse.ui.internal.EditorManager$5.runWithException(EditorManager.java:972)
	at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3563)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3212)
	at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
	at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1600)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
	at org.csstudio.utility.product.Workbench.runWorkbench(Workbench.java:116)
	at org.csstudio.startup.application.Application.startApplication(Application.java:255)
	at org.csstudio.startup.application.Application.start(Application.java:105)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
"VM Thread" prio=10 tid=0x00007f61101c5800 nid=0x10ed runnable
"GC task thread#0 (ParallelGC)" prio=10 tid=0x00007f6110020000 nid=0x10e5 runnable
"GC task thread#1 (ParallelGC)" prio=10 tid=0x00007f6110022000 nid=0x10e6 runnable
"GC task thread#2 (ParallelGC)" prio=10 tid=0x00007f6110023800 nid=0x10e7 runnable
"GC task thread#3 (ParallelGC)" prio=10 tid=0x00007f6110025800 nid=0x10e8 runnable
"GC task thread#4 (ParallelGC)" prio=10 tid=0x00007f6110027800 nid=0x10e9 runnable
"GC task thread#5 (ParallelGC)" prio=10 tid=0x00007f6110029800 nid=0x10ea runnable
"GC task thread#6 (ParallelGC)" prio=10 tid=0x00007f611002b000 nid=0x10eb runnable
"GC task thread#7 (ParallelGC)" prio=10 tid=0x00007f611002d000 nid=0x10ec runnable
"VM Periodic Task Thread" prio=10 tid=0x00007f6110209000 nid=0x10f4 waiting on condition
JNI global references: 774
Heap
 PSYoungGen      total 36864K, used 19239K [0x00000007d6f00000, 0x00000007d9800000, 0x0000000800000000)
  eden space 31744K, 44% used [0x00000007d6f00000,0x00000007d7cceeb8,0x00000007d8e00000)
  from space 5120K, 99% used [0x00000007d9300000,0x00000007d97faf98,0x00000007d9800000)
  to   space 5120K, 0% used [0x00000007d8e00000,0x00000007d8e00000,0x00000007d9300000)
 ParOldGen       total 83968K, used 23044K [0x0000000784e00000, 0x000000078a000000, 0x00000007d6f00000)
  object space 83968K, 27% used [0x0000000784e00000,0x0000000786481188,0x000000078a000000)
 PSPermGen       total 30720K, used 30289K [0x000000077a800000, 0x000000077c600000, 0x0000000784e00000)
  object space 30720K, 98% used [0x000000077a800000,0x000000077c594718,0x000000077c600000)
Re: generic CSS version Kasemir, Kay
generic CSS version Florian Feldbauer
Re: generic CSS version marcus . michalsky
Re: generic CSS version Michael Davidsaver
Re: generic CSS version Florian Feldbauer
Prev: Qwt 6.1.2 build issue under Ubuntu 15.10 Abdalla Ahmad
Next: Re: generic CSS version Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: generic CSS version Michael Davidsaver
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
