The Point Grey driver is not compatible with the areaDetector-1-9-1 version. If you are using synApps_5_7 that is quite old, and has old versions of asyn, etc.
Here is what I recommend:
Get the latest released version of the following from https://github.com/epics-modules
asyn
busy
calc
sscan
autosave
iocStats
You can use git clone and then git checkout to checkout the latest released version, or you can get the appropriate tar file from github.
You can either copy the top-level synApps_5_7/support/configure tree to a new location or get a new version at
https://github.com/EPICS-synApps.
Get the following from https://github.com/areaDetector
areaDetector R2-4
ADCore R2-4
ADBinaries R2-2
ADExample R2-1
ADPointGrey R2-3
You can use git clone and then git checkout to checkout the versions listed above, or you can get the appropriate tar file from github.
Build the new versions of the synApps modules. Then follow the areaDetector/INSTALL_GUIDE.md to build areaDetector.
Let me know if you have questions or problems.
On Behalf Of ???
Sent: Wednesday, March 16, 2016 8:51 AM
To: [email protected]
Subject: A Problem While Installing areaDetector
Hello :
I'm a student of Tsinghua University and I have a problem about installing areaDetector.
I have already installed synApps and base , the asyn is in the synApps . I want to use PointGrey camera so I want to install an another areaDetector because the one in synApps didn't have Point Grey driver . But after I changed the path and others just like
the INSTALL_GUIDE.md said , there is a mistake when I tpye "make". It says
"/disk1/epics/distrib/synApps_5_7/support/areaDetector-1-9-1/ADApp/simDetectorSrc/O.linux-x86_64/simDetectorApp_registerRecordDeviceDriver.cpp:607: undefined reference to `pvar_func_NDFileMagickRegister'
collect2: error: ld returned 1 exit status"
At first , it can not find files "libbusy.a" and something like that.So I copied those file into the folder areaDetector/lib/linux-x86_64 , and it worked. I have already defined support and its subdirectories and I think these problems should not happen . I
hope ypu can solve my problem .
Thank you!
