1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: A Problem While Installing areaDetector
To: [email protected]
Date: Wed, 16 Mar 2016 21:50:33 +0800 (GMT+08:00)
Hello :
I'm a student of Tsinghua University and I have a problem about installing areaDetector.
 I have already installed synApps and base , the asyn is in the synApps . I want to use PointGrey camera so I want to install an another areaDetector because the one in synApps didn't have Point Grey driver . But after I changed the path and others just like the INSTALL_GUIDE.md said , there is a mistake when I tpye "make". It says
 "/disk1/epics/distrib/synApps_5_7/support/areaDetector-1-9-1/ADApp/simDetectorSrc/O.linux-x86_64/simDetectorApp_registerRecordDeviceDriver.cpp:607: undefined reference to `pvar_func_NDFileMagickRegister'
collect2: error: ld returned 1 exit status"
At first , it can not find files "libbusy.a" and something like that.So I copied those file into the folder areaDetector/lib/linux-x86_64 , and it worked. I have already defined support and its subdirectories and I think these problems should not happen . I hope ypu can solve my problem .
Thank you!
RE: A Problem While Installing areaDetector Mark Rivers
Prev: RE: Tech-talk Digest, Vol 10, Issue 123 Mark Rivers
Next: RE: Question about softioc "Connection refused" problem Mazanec Tomáš
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: RE: A Problem While Installing areaDetector Mark Rivers
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
