1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: NDTransform Plugin does not work
To: "'Xu, Yihui'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 14 Mar 2016 15:03:36 +0000
Your NDTransform_settings2.png screen shot shows an inconsistency.  It is the medm screen for the new version of the NDTransform plugin (ADCore R2-1 and later), with the F characters in various orientations.  But the transform type menu is showing “Transpose” which is not a valid choice for the new version, so you must be running the pre R2-1 version of the database.  I suggest you only use the new version of the plugin.
From: [email protected] [mailto:[email protected]] On Behalf Of Xu, Yihui
Sent: Monday, March 14, 2016 9:11 AM
To: [email protected]
Subject: NDTransform Plugin does not work
Dear all
I have tried to use the NDTransform Plugin to rotate my images, however, no matter use the old version or the new version by Christian Roehrig, neither my saved Tiff-file nor imagej ADlive viewer show any change.
Attached please find my settings for both the NDtranform plugins.
Cheers
Yihui
NDTransform Plugin does not work Xu, Yihui
Prev: Scan problem when the ioc behave as client Tasaddaq Khan
Next: RE: Scan problem when the ioc behave as client Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: NDTransform Plugin does not work Mark Rivers
Next: Scan problem when the ioc behave as client Tasaddaq Khan
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
