Hi Yihui,
I suspect the problem is that you have not told the NDFileTIFF plugin or the NDStdArrays plugin for ImageJ to get their data from the NDTransform plugin. They are probably
getting their data directly from the detector, which is asyn port TIM in your case. You need to set the NDArrayPort PV in the NFFileTIFF and NDStdArrays plugin to TRANS1, not TIM.
Dear all
I have tried to use the NDTransform Plugin to rotate my images, however, no matter use the old version or the new version by Christian Roehrig, neither my saved Tiff-file nor imagej ADlive viewer show any change.
Attached please find my settings for both the NDtranform plugins.
Cheers
Yihui
- NDTransform Plugin does not work Xu, Yihui
RE: NDTransform Plugin does not work Zhang, Zhan
Scan problem when the ioc behave as client Tasaddaq Khan
<2016>
RE: NDTransform Plugin does not work Mark Rivers
<2016>
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
