1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Trouble using MCS mode with mcaR7-6 and Canberra DSA-2000
To: "'hank'" <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 12 Mar 2016 00:16:17 +0000
Hi Hank,
The EPICS support for the DSA-2000 does not include support for the MCS mode.  I have the manual for the DSA-2000 network protocol, and the commands to configure the MCS mode are documented.  If you are interested in implementing them I'll be happy to send you a copy of the manual.  I don't think I'll have the time or interest to do it myself.
How fast do you want to do your time binning?  If it is not too fast you may be able to do it in software using the normal PHA mode and ROIs in the mca record.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of hank
Sent: Friday, March 11, 2016 11:17 AM
To: [email protected]
Subject: Trouble using MCS mode with mcaR7-6 and Canberra DSA-2000
Hello, I'm an individual user of EPICS, initially mainly to make use of
the MCA components and AIM support with a Canberra DSA-2000, but I'm
also having success using it for control of other instruments and data
acquisition around the lab.
I'm trying to use the DSA-2000 in MCS mode, without any luck so far, but
I'll admit I'm unclear on some of the terminology in the AIM/ICB setup
instructions, MCA and DSP settings, and even what to expect in general.
MCA/PHA mode seems to work fine, so I think most of my EPICS MCA
installation is working correctly.
 From what I've read about the MCS function in the DSA-2000 manual, I
thought I should be able to set a ROI, Mode=MCS, dwell time, and
internal channel advance, and have it work in simple MCS mode. I see
most of these controls in the MEDM MCA Setup window, although I'm not
sure where MCS-related ROI(s) would be specified, or if that is
possible. The AIM/ICB setup instructions give an example for collecting
"20 spectra". Does that mean 20 ROIs for which MCS data is collected?
The behavior I'm seeing is that when I set the mode to MCS in the MCA
Setup MEDM window, nothing seems to change from the normal MCA/PHA
display in the mcaTest:aim_adc1 MEDM window. I expected to see the graph
change to one with the channels representing the MCS time bins. Also
when I try to set the dwell time to something other than zero, it
immediately reverts back to zero at the next update.
Some system info and modules installed for using MCA:
ARCH: Debian, linux-x86_64
mcaR7-6
asyn4-24
autosave-5-4-2
base-3.14.12.4
busy-1-6
calc-3-4-1
medm3_1_9 and caqtdm-4.0.2
seq-2.1.10
sscan-2-10
std-3-2
also using StreamDevice and StripTool for other apps
I'm not using a multiplexer, and I want to count across 1024 time bins
(each of (dwell time) per bin), so I start up with the commands:
< envPaths
epicsEnvSet(STARTUP,$(TOP)/iocBoot/$(IOC))
dbLoadDatabase("../../dbd/mcaCanberra.dbd",0,0)
mcaCanberra_registerRecordDeviceDriver(pdbbase)
# AIMConfig(portName, ethernet_address, portNumber(1 or 2), maxChans,
#           maxSignals, maxSequences, ethernetDevice)
AIMConfig("AIM1/1", 0x801c, 1, 1024, 1, 1, "eth0")
dbLoadRecords("/home/hank/epics/mcaR7-6/mcaApp/Db/mca.db",
"P=mcaTest:,M=aim_adc1,DTYP=asynMCA,INP=@asyn(AIM1/1 0),NCHAN=1024")
icbConfig("icbDsp1", 0x801c, 0, 4)
dbLoadRecords("/home/hank/epics/mcaR7-6/mcaApp/Db/icbDsp.db",
"P=mcaTest:,DSP=dsp1,PORT=icbDsp1")
DSA2000Config("DSA2000",0x801c)
dbLoadRecords("/home/hank/epics/mcaR7-6/mcaApp/Db/DSA2000_HVPS.db",
"P=mcaTest:,HVPS=hvps1:,PORT=DSA2000,LIMIT=5000")
< save_restore.cmd
set_pass0_restoreFile("DSA2000_settings.sav")
set_pass1_restoreFile("DSA2000_settings.sav")
iocInit()
# save settings every thirty seconds
create_monitor_set("DSA2000_settings.req",30,"P=mcaTest:"
This results in the behavior I described above.
Results of AIM and ICB showModules:
epics> mcaAIMShowModules
Module     Type  HW rev.  FW rev.  Owner name      Owner ID Status
Memory size Free address
NI00801c    1       2        7       lab01     08:00:27:AF:23:44
Reachable     262140      00001000
epics> icbShowModules
NI801C:0   9  O5�   12982655
Hex translation:
00000000  4e 49 38 30 31 43 3a 30  20 20 20 39 20 20 10 4f |NI801C:0
9  .O|
00000010  35 ef bf bd 11 7f 20 20  20 31 32 39 38 32 36 35 |5.....
1298265|
00000020  35 0a                                             |5.|
Hopefully someone will be able to tell me what I'm doing wrong. Thanks
to the EPICS contributors for the excellent software, and thanks in
advance for any help you can provide.
Hank Ball
Re: Trouble using MCS mode with mcaR7-6 and Canberra DSA-2000 hank
Prev: RE: EPICS Archiver Appliance web interface error 김지화(빔라인장치팀)
Next: Re: Trouble using MCS mode with mcaR7-6 and Canberra DSA-2000 hank
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Trouble using MCS mode with mcaR7-6 and Canberra DSA-2000 hank
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
