Thanks. I had hoped to avoid using the subroutine record, but that is
pretty simple and maintainable.
Kevin
On 3/10/16 10:39 AM, Florian Feldbauer wrote:
> Hey Kevin,
> I had the same problem once with a HV power supply.
> I solved the problem this way:
> - Read the value via StreamDevice into a longin record
> - Use a sub-record to convert 32bit-int to 32bit-float
> The subroutine is quiet easy:
> union ficonv{
> float float_val;
> unsigned int int_val;
> static long intToFloat(subRecord *prec) {
> union ficonv myconf;
> myconf.int_val = prec->a;
> prec->b = myconf.float_val;
> return 0;
> I hope this helps!
> Cheers
> Florian
- stream protocol question: ASCII hex to 32-bit float Kevin Peterson
- Re: stream protocol question: ASCII hex to 32-bit float Florian Feldbauer
Re: stream protocol question: ASCII hex to 32-bit float Kevin Peterson
Re: EPICS Archiver Appliance web interface error Shankar, Murali
<2016>
Re: stream protocol question: ASCII hex to 32-bit float Eric Norum
<2016>
