Hi Michael,
When boot time automatically loaded SLAC MRF "pci_mrfevr".
[root@amc725 ~]# lsmod | grep mrf
mrf 13648 0
uio 19175 1 mrf
parport 40636 1 mrf
pci_mrfevr 53687 0
I manually removed.
[root@amc725 opt]# /sbin/rmmod pci_mrfevr
[root@amc725 opt]# lsmod | grep mrf
mrf 13648 0
uio 19175 1 mrf
parport 40636 1 mrf
Restarted mrfioc2 but same error.
mrmEvrSetupPCI("PMCEVR",0xe,1,0)
Device PMCEVR 14:1.0
Using IRQ 16
Failed to open uio device for PCI device 0000:0e:01.0: No such file or directory
Failed to enable interrupt
How do I disable/remove this "pci_mrfevr" ?
-Jihwa
보낸 사람: Michael Davidsaver <[email protected]>
보낸 날짜: 2016년 3월 11일 금요일 오후 11:18
받는 사람: 김지화(빔라인장치팀); [email protected]; [email protected]
제목: Re: mrfioc2 error at uTCA platform
On 03/10/2016 11:58 PM, 김지화(빔라인장치팀) wrote:
> Hi Michael,
> I've attached system information.
> Module Size Used by
> mrf 13648 0
> uio 19175 1 mrf
> parport 40636 1 mrf
> pci_mrfevr 53687 0
This shows that both kernel modules are loaded. To simplify
troubleshooting please ensure that only the 'mrf' module is loaded and
not 'pci_mrfevr'.
Only one linux driver can be attached to a particular PCI device. This
will typically be the first one loaded, in this case 'pci_mrfevr'. I
should also note that, with modern Linux drivers, having to manually
create a file in /dev/ is a sure sign that something is wrong.
- RE: mrfioc2 error at uTCA platform 김지화(빔라인장치팀)
- Re: mrfioc2 error at uTCA platform Konrad, Martin
- Re: mrfioc2 error at uTCA platform Michael Davidsaver
EPICS Archiver Appliance web interface error 김지화(빔라인장치팀)
Re: stream protocol question: ASCII hex to 32-bit float Kevin Peterson
<2016>
<2016>
