1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: stream protocol question: ASCII hex to 32-bit float
To: EPICS tech talk <[email protected]>
Date: Thu, 10 Mar 2016 10:28:39 -0600
I have a helium sensor that responds to a query with this reply:
  :80gv<VVVVVVVV><FFFFFFFF><CCCC><cr>
Where the non-constant parts of the response are ASCII hex characters
representing the following values:
  <VVVVVVVV> = (32 bit floating point) The current gas value
  <FFFFFFFF> = (32 bit unsigned integer) The sensor status
  <CCCC> = (16 bit unsigned integer) The message checksum
Is there a straightforward way to parse the floating point value using
StreamDevice format converters?
The raw double converter %R doesn't work, presumably because it is
interpreting the ASCII chars as bytes, rather than hex values.
The value can be read as an int with %08X, but it isn't obvious how to
then cast that value as a float.
Kevin
Kevin M. Peterson
(630) 252-8644
[email protected]
Re: stream protocol question: ASCII hex to 32-bit float Florian Feldbauer
Re: stream protocol question: ASCII hex to 32-bit float Eric Norum
Prev: RE: mbbo/mbbi and bits subset Mark Rivers
Next: Re: stream protocol question: ASCII hex to 32-bit float Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
