Hi Gennaro,
The mbbo record has 16 enum choices. However, the values associated with each enum choice are 32-bit integers. So you can access all 32 bits in your register using an mbbo record.
Sent: Thursday, March 10, 2016 8:19 AM
To: Mark Rivers
Cc: [email protected]
Subject: RE: mbbo/mbbi and bits subset
I just realized that a mbbo can contain up to 16 bit value...
it is possible to specify that a record can contain a 32 bit value ?
the record documentation does not provide this information...
Gennaro
On Thu, 10 Mar 2016, [email protected] wrote:
> Hi Mark,
> I did it with your suggestion by asynMask and everything works fine !!
> Thanks,
> Gennaro
> On Thu, 10 Mar 2016, Mark Rivers wrote:
>> Hi Gennaro,
>> You can do what you want using the asynUInt32Digital support and the
>> @asynMask INP syntax.
>> record(mbbo,"Acquire") {
>> field(DTYP,"asynUInt32Digital")
>> field(OUT,"@asynMask(myPort , 0, 0x3 , 1.0) ")
>> field(ZRST,"Start acquire")
>> field(ONST,"Stop acquire")
>> field(ZRVL,"0x2")
>> field(ONVL,"0x3")
>> You can use multiple mbbo/mbbi records to access different adjacent bits in
>> your register using this technique.
>> The asyn device support uses the NOBT, SHFT, and MASK fields of the
>> mbbo/mbbi records documented here:
>> https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Multi-Bit_Binary_Output
>> Mark
>> From: [email protected] [[email protected]] on
>> behalf of [email protected] [[email protected]]
>> Sent: Thursday, March 10, 2016 4:54 AM
>> To: [email protected]
>> Subject: mbbo/mbbi and bits subset
>> Hi,
>> I'm using mbbo and mbbi record types to write and read
>> some registers from/to ASYN driver I'm developing;
>> some registers refers to a single aspect of acquisition
>> (e.g. channel threshold) and with a simple mbbo record
>> to write and a mbbi record to read back, everything works
>> fine...
>> other registers refers to a setup/control functions
>> and using the same mbbo/mbbi approach works fine if
>> the user address (read/write) every time the whole register;
>> I know mbboDirect for bitwise access of a record value but
>> is there a method to address (read/write) through a record
>> a "bits subset" of a "main" mbbo record ?
>> e.g. acquisition control:
>> bit[16...2] <don't care>
>> bit[1...0]
>> 11 stop acquisition
>> 10 start acquisition
>> 01 do something...
>> 00 do something...
>> which is a simple method to access "directly" bitset [0...1]
>> in order to have a record I can use to write 11 (3) to stop acquisition,
>> 10 (2) to start acquisiton and so on ?
>> Thanks in advance,
>> Gennaro
>> Gennaro Tortone
>> INFN Napoli
>> Italy
>> tel: +39 81 676169
>> "Computer Science is no more about computers
>> than astronomy is about telescopes."
>> - Edsger Dijkstra
Gennaro Tortone
INFN Napoli
Italy
tel: +39 81 676169
- Edsger Dijkstra
- RE: mbbo/mbbi and bits subset [email protected]
- mbbo/mbbi and bits subset [email protected]
- RE: mbbo/mbbi and bits subset Mark Rivers
<2016>
<2016>
