Hi Mark, Ron Ok so it seems to be the controller that cannot do 60Hz updates. Thanks for your help. Why do you need high status update rates? To keep more accurate track of the readout of the motor positions during fly scans. We are trying to avoid using pulse outputs from the controllers as well as trying to avoid using encoders. If status updates are only used for user feedback displays, then 5 Hz is more than adequate. You are right 5Hz is more than adequate for client display screens, I believe caqtdm (which we use here) updates at 5Hz when the Update Type is set to timed (They also have a direct setting where the channel defines the update rate). Best, Ali -- Alireza Panna University of Maryland, College Park On Wed, Mar 9, 2016 at 12:53 PM, Ron Sluiter <[email protected]> wrote:
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
