1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem in running simple tutorial problems
To: "Matt Newville" <[email protected]>
Date: Tue, 08 Mar 2016 14:09:59 +0100
Hi all,
I should mention again I have no prior experience in working with epics or any server.
So my naive first thought was that:
In [1]: import epics
In [2]: p = epics.PV('LargeWaveform')
should start a server and create the PV, which is apparently not the case...?
So I started a "SimpleServer" using PCASpy. But here all PVs need to be defined before starting the server (correct?)? I was able to modify the data in these pre defined PVs with pre defined array sizes. Yet I want to be able to store arrays of unknown/changing size in these PVs!
So to sum up:
How do I start an epics server? Is it possible to create PVs during operation/how? How do I store arrays of arbitrary size in them?
From what I gather from the wiki all this should be possible, but I seem to be missing a step...
(I'm working locally so firewall should not be an issue for now...)
Thanks in advance,
Jan
On Mon, 7 Mar 2016 10:44:45 -0600
 Matt Newville <[email protected]> wrote:
Hi Jan,
On Mon, Mar 7, 2016 at 7:43 AM, Jan Cedric Hönig <
I'm planning to use epics, but I"m stuck right at the beginning.
I work on scientific linux 6 so first I start python:
ipython
Python 2.7.5 (default, Jun  5 2014, 14:38:05)
Then I try simple epics commands:
In [3]: p.connect
Out[3]: <bound method PV.connect of <PV 'LargeWaveform': not connected>>
But I am unable to connect any of my PVs. Am I doing something wrong?
'connect' is a method of a PV.  To run this method, add parens:
  p.connect()
The connection should happen automatically and soon, so that you don't need
to explicitly run the connect method, and can just access the data:
  p.get()
You can also checked the value of `p.connected`, which will be True once
(and if) the PV is connected.
--Matt
Re: Problem in running simple tutorial problems Matt Newville
Problem in running simple tutorial problems Jan Cedric Hönig
Prev: CSS write buffer size 吴煊
Next: RE: Array of strings with asyn? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Problem in running simple tutorial problems Matt Newville
Next: Re: Problem in running simple tutorial problems Matt Newville
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
