1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Q: Are any tools using gui_group() properties?
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 8 Mar 2016 09:07:34 +0100
Dear All,
Before seriously considering a redesign of the gui_group() properties in record definitions (intended as hints to DB configuration tools to provide a comprehensively grouped view of a record's fields), an important question:
    Are there any tools or mechanisms in use (other than VDCT) that use the gui_group() properties and might be broken?
Please point out any usage of this feature. (In case you know, add the way it is used: discovered from DBD file, using the header file from base, hard coded, ...)
Thanks a lot,
~Ralph
Re: Q: Are any tools using gui_group() properties? Rolf Keitel
Prev: Re: Array of strings with asyn? Michael Davidsaver
Next: CSS write buffer size 吴煊
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Array of strings with asyn? Vasquez Stanescu, Jesus A
Next: Re: Q: Are any tools using gui_group() properties? Rolf Keitel
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
