Small comment:
I would suggest to *never* put the IOC name into a record name.
Which IOC a specific PV is served from is an implementation detail
that is irrelevant to the user/client and should not be exposed.
Consider that you have to move the record to a different IOC, e.g.
because you split up an IOC after it hits some resource limits.
Will you be renaming all PVs as you move them? Will you keep the
names that are now misleading? This is a recipe for trouble.
BTW: The same applies to putting the record type (ai, bi, ...) into
the record name. If you ever want to change the implementation (e.g.
use a mbbi instead of a bi because you define additional states),
your names will be wrong or have to be changed.
Just my 2cts...
~Ralph
On 04/03/2016 11:21, Mazanec Tomáš
wrote:
Hi
What if you create a scheme for PVs naming which will include
information about system and device ?
Something like naming convention for PVs, e.g.:
$(SYSTEM)-$(DEVICE)-$(IOC):Current_Setpoint
where:
SYSTEM=MAGNETS2
DEVICE=PSU
IOC=POW-CNTRL
So you don't have to program extra stuff to EPICS/CA
applications.
Tomas
Hi, everyone
I have a question about Archive. In CSS, I select
Archive Search then I can see a table including "PV Name"
and "Name" . But some CSS user in our team want to see the
device name which the "PV Name" belongs to. I know that
the "PV Name" list is from a XML file. How can I add one
column in the XML file or can I do some special setting in
the CSS to realize 3 columns dispay in the Archive Search
panel?
Min Yue
Institute of Modern Physics, Chinese Academy of Sciences
509 Nanchang Road, Lanzhou, 730000, P.R.China
Tel:+86-0931-4969469
Handy: +86-18509316383
- question about archive 岳敏
- RE: question about archive Mazanec Tomáš
CSS 4.1: performance drop when using linking container and macros Zumbruch, Peter Dr.
Re: generic CSS version Konrad, Martin
<2016>
Re: question about archive Kasemir, Kay
<2016>
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
