1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: generic CSS version
To: [email protected]
Date: Wed, 2 Mar 2016 11:55:26 -0500
On 03/02/2016 10:31 AM, [email protected] wrote:
Hello Florian,
you didn't mention the OS you are running CSS upon. But if you (try to) run Eclipse 3.x (or a CSS based on it) on a more or less up-to-date linux distribution
there are some known bugs related to GTK:
* KDE Bug 327441 - Using oxygen-gtk2 causes eclipse/swt to crash (https://bugs.kde.org/show_bug.cgi?id=327441)  --> our workaround is to use another theme by setting GTK2_RC_FILES=/usr/share/themes/Raleigh/gtk-2.0/gtkrc
* Eclipse Bug 404776 causes a crash when opening Help (https://bugs.eclipse.org/bugs/show_bug.cgi?id=404776) --> our workaround is to open it in an external browser instead, i.e. setting the VM param -Dorg.eclipse.swt.browser.DefaultType=mozilla
* displaying issues when using GTK3 --> our workaround is to use GTK2 instead by setting SWT_GTK3=0
I can add one to this list: https://bugs.eclipse.org/bugs/show_bug.cgi?id=464554
I actually spent some time looking into the horrible mess that lives at the bottom of eclipse/SWT.  From what I can tell, in some situations, GTK pointers are being mistakenly passed to libcairo functions, which of course leads to a crash.  The wonders of JNI...
cs-studio-nsls2 comes with some defaults which avoid this, by using gtk2 w/o cairo.  Of course gtk2 will eventually go away, so not a permanent solution.
An excerpt from cs-studio.ini
--launcher.GTK_version
2
-vmargs
-Dorg.eclipse.swt.internal.gtk.cairoGraphics=false
-Dorg.eclipse.swt.internal.gtk.useCairo=false
You might also get some improvement by recompiling the eclipse-gtk C glue code against the headers provided by your linux distribution.  Though be warned that this is an errand only for those who can tolerate significant amounts of frustration.
https://github.com/mdavidsaver/eclipse-tricks
Re: generic CSS version Florian Feldbauer
Re: generic CSS version marcus . michalsky
Prev: Re: generic CSS version marcus . michalsky
Next: STAR EPICS VM environment update Jiro Fujita
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: Re: generic CSS version Florian Feldbauer
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
