Hi Mark,
Yes, I am using asynManager calls. I was not calling updateTimeStamp
and getTimeStamp. Troubles solved.
Thanks for the help!
Enrique Berrnal.
El 29/02/2016 a las 15:57, Mark Rivers escribió:
Hi Enrique,
Is your driver written using asynPortDriver or using native asynManager calls?
If you are using asynPortDriver then is your driver calling asynPortDriver::updateTimeStamp each time you want to update the timestamp?
If you are using native asynManager calls then is your driver calling pasynManager->updateTimeStamp and pasynManager->getTimeStamp each time you want to update and set the timestamp?
You can find examples of using it in the following asyn files:
asyn/testErrrorsApp/src/testErrors.cpp
testAsynPortDriverApp/src/testAsynPortDriver.cpp
There are also examples in all of the areaDetector drivers, for example:
areaDetector/ADExample/exampleApp/simDetectorSrc/simDetector.cpp:
From: [email protected] [[email protected]] on behalf of Enrique Bernal [[email protected]]
Sent: Monday, February 29, 2016 8:27 AM
To: [email protected]
Subject: PV with TSE=-2 and SCAN=I/O Intr returns <undefined> time.
Dear all,
I am working with asynR4-27 on a Linux machine. I have followed the Support for EPICS Time Stamps in asyn (<http://www.aps.anl.gov/epics/modules/soft/asyn/R4-27/AsynTimeStampSupport.pdf>http://www.aps.anl.gov/epics/modules/soft/asyn/R4-27/AsynTimeStampSupport.pdf) but I am still having some troubles.
When I camonitor a PV with TSE=-2 and SCAN=I/O Intr the time obtained is <undefined>, but if I camonitor the same PV with TSE=0 and I/O Intr everything is ok.
I have registered myTimeStampSource with: asynRegisterTimeStampSource(const char *portName, const char *functionName). This is correct, it does not show any error at IOC initialization.
I have coded myTimeStampSource with some printf which are never printed, so maybe it is never being called.
I have registered this function with: epicsRegisterFunction(myTimeStampSource) and added in dbd file, the line: function(“myTimeStampSource”)
Any advice would be highly appreciated.
Thanks in advance.
Enrique Bernal.
- PV with TSE=-2 and SCAN=I/O Intr returns <undefined> time. Enrique Bernal
- RE: PV with TSE=-2 and SCAN=I/O Intr returns <undefined> time. Mark Rivers
Re: Raspberrypi GPIO access through EPICS Florian Feldbauer
generic CSS version Florian Feldbauer
<2016>
read value from ai record to Device support ishita bhatia
<2016>
