1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Questions regarding PV access within CSS
To: "Kasemir, Kay" <[email protected]>
Date: Tue, 1 Mar 2016 10:42:42 +0200
Hello Kay
Thank you for your response.
For the simulated PV I found it in the documentation, I found it straightforward, I did a simple Proof-of-Concept and it should do the thing.
For the PVManager API, I did some search and could not figure out how to use it in a python script, also I did not get much documentation on what API functions available, most of the result I found were on how to use it inside Java code. Do you have any reference on using this API inside a script?
Thanks in advance!
Abdalla.
On 02/29/2016 04:38 PM, Kasemir, Kay wrote:
Hi:
On Feb 29, 2016, at 7:57 AM, Abdalla Al-Dalleh <[email protected]> wrote:
Is it possible to read a PV value using its string name?
Check the PVManager functions.
There’s something like   pv(‘name of PV’) for that.
In a PVManager formula, you can use (note the backquotes)
    =`name of PV` + 5
2nd Related question, as you all know, when you add a script to CSS it is executed (by default) on a trigger from a PV you add. How to have the same idea but without PVs? i.e., executing a script continuously without an external trigger so for example to update a widget's text value.
You can use “sim:ramp” as a PV that periodically triggers your script.
So it’s still a PV, but one that’s simulated inside CSS.
See online help for description on the simulated PV syntax.
-Kay
Re: Questions regarding PV access within CSS Kasemir, Kay
Questions regarding PV access within CSS Abdalla Al-Dalleh
Prev: RE: PV with TSE=-2 and SCAN=I/O Intr returns <undefined> time. Mark Rivers
Next: read value from ai record to Device support ishita bhatia
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Questions regarding PV access within CSS Kasemir, Kay
Next: Re: Questions regarding PV access within CSS Kasemir, Kay
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
