Hi:
> On Feb 29, 2016, at 7:57 AM, Abdalla Al-Dalleh <[email protected]> wrote:
> Is it possible to read a PV value using its string name?
Check the PVManager functions.
There’s something like pv(‘name of PV’) for that.
In a PVManager formula, you can use (note the backquotes)
=`name of PV` + 5
> 2nd Related question, as you all know, when you add a script to CSS it is executed (by default) on a trigger from a PV you add. How to have the same idea but without PVs? i.e., executing a script continuously without an external trigger so for example to update a widget's text value.
You can use “sim:ramp” as a PV that periodically triggers your script.
So it’s still a PV, but one that’s simulated inside CSS.
See online help for description on the simulated PV syntax.
-Kay
- Re: Questions regarding PV access within CSS Abdalla Al-Dalleh
- Questions regarding PV access within CSS Abdalla Al-Dalleh
PV with TSE=-2 and SCAN=I/O Intr returns <undefined> time. Enrique Bernal
RE: PV with TSE=-2 and SCAN=I/O Intr returns <undefined> time. Mark Rivers
<2016>
<2016>
