Hi Gerrit
To answer your original question: Version 2.2 of the sequencer no longer
has the devSequencer device support. You should be able to proceed with
seq-2.2.3 by deleting the offending line from PI_GCS2Support.dbd . If
the latter file is generated by make and not a source file, remove the
line saying "DBD_whatever += devSequencer.dbd" from the Makefile. You
probably also need to remove a line that says something like "xxx_LIBS
+= devSequencer" from the Makefile.
Cheers
Ben
On 02/22/2016 11:43 AM, Gerrit Kühn wrote:
> Dear all,
> I'd like to use the motor record (for the first time :-) with a Newport
> AG_UC controller. For this, I installed a mrecent base (3.15.3), the latest
> motor record (6.9), asyn (4.28), seq (2.2.3) and a couple of other
> dependencies.
> Motor itself appears to compile cleanly, but I cannot get the examples to
> work. I get the following error message when building the WithAsyn parts:
> dbdExpand.pl: Duplicate definition of record type ''
> Context: recordtype(asyn) in file
> '/opt/rtapps/epics-3.15.3_long/modules/asyn/dbd/asynRecord.dbd' in file
> '/opt/rtapps/epics-3.15.3_long/modules/asyn/dbd/asyn.dbd' in file
> '../../../dbd/PI_GCS2Support.dbd' while reading 'PI_GCS2Support.dbd' to
> create 'WithAsyn.dbd' dbdExpand.pl: Can't find file 'devSequencer.dbd'
> while reading 'devSequencer.dbd' to create 'WithAsyn.dbd' Your Makefile
> may need this dependency rule: $(COMMON_DIR)/WithAsyn.dbd:
> $(COMMON_DIR)/devSequencer.dbd dbdExpand.pl: Exiting due to errors
> In the release notes of the sequencer I find
> Removed devSequencer
> The (broken and ugly) sequencer device support was removed.
> Consequently, seqFindProgByName was be removed as it is no longer needed.
> What is the recommended solution here? Use an older version of the
> sequencer (that still comes with devSequencer)? Or is this only needed for
> PI_GCS2 devices, so I could leave these out (as I only need support for
> ag_uc)?
> cu
> Gerrit
"Make it so they have to reboot after every typo." ― Scott Adams
signature.asc
Description: OpenPGP digital signature
- Re: Motor examples missing devSequencer Gerrit Kühn
- Motor examples missing devSequencer Gerrit Kühn
How to cs-studio Scan System Patard Charles-Henri
Re: How to cs-studio Scan System Kasemir, Kay
<2016>
<2016>
