1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem when building debian package IOC
To: "Konrad, Martin" <[email protected]>, "[email protected]" <[email protected]>, "Shen, Guobao" <[email protected]>
Date: Mon, 22 Feb 2016 16:33:03 +0000
Thanks for your reply. But according to "Deb maint-guide" as follows, the package.install files are supplementary rather than necessary. I did not add RELEASE to install file in debian directory and even if there is no install file, RELEASE file will still be built into my debian package. I think it is related to "make install" behavior of my EPICS application, since most files in debian directory are unchanged after dh_make.
5.11. install
If there are files that need to be installed into your package but your standard make install won't do it, put the filenames and destinations into this install file.
Lin
Sent: Sunday, February 21, 2016 11:28 PM
To: Wang, Lin; [email protected]
Hi Lin,
> my problem is that the configure/RELEASE file will be the
> "/usr/lib/epics/configure/RELEASE" file in the package as well, which
>  conflicts with the existing one of EPICS base and causes failure
> when install the Debian package.
You probably do not want to install the RELEASE file of your IOC along
with your binaries. Exclude it from the list of files to be installed
(e.g. remove it from debian/<package-name>.install) and you should be good.
HTH,
Martin
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Re: Problem when building debian package IOC Konrad, Martin
Prev: Re: referencing libraries Andrew Johnson
Next: Re: Problem when building debian package IOC Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Problem when building debian package IOC Konrad, Martin
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
