Hi Ulrik and Mark,
I was comparing my procedure for submitting patches to areaDetector
to
the areaDetector-Git-Workflows
wiki page and noticed that the wiki doesn't
recommend feature branches for contributors. I found w/ my
areaDetector
contributions that it was best not to make any commits directly on
my forked
master branch.
While it probably works out ok if there's a simple change that gets
accepted
right away, problems happen if the change isn't accepted right away,
or if you
have multiple pull requests and some need more work or aren't
accepted.
Here's the procedure I've been using.
# To submit a patch as a new pull request
1. Make sure your master branch is uptodate
git pull origin master
2. Switch workspace to master prior to creating each new feature
staging branch!
git checkout master
3. Create feature staging branch
git checkout -b feature-name
4. Apply patch (or make changes to files directly)
patch --strip 0 -i path_to_patch_file
5. Use git diff and git status to make sure all is well
5a. Be sure to expand all tabs in any changed lines
6. Commit changes to local git repo
git commit -a -m "What this patch does"
7. Push back to orgin on github
git push -u origin feature-name
8. Go to github and submit pull request(s) to developer's fork
This has the advantage of keeping each proposed change on it's own
branch
where it can be tweaked or discarded as needed w/o impacting the
master branch.
What do you guys think?
Should this be added to the wiki?
- Bruce
Hi Han,
In order to contact the developers (at least for areaDetector - but probably also for other modules) it is useful to simply create an issue-ticket on the github repository. For areaDetector this is often where contributors start by presenting a new idea or change that they would like to see and a discussion is had about how to best implement the new feature. If you start the description by volunteering to work on it then maintainers are usually happy to guide you in the right direction :-)
See for example a recent ticket on areaDetector/ADCore where we had an extensive debate about a requested change: https://github.com/areaDetector/ADCore/issues/145 . I expect it is likely to be followed up with a Pull Request later on - at which point we will review and discuss the implementation details.
Cheers,
Ulrik
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Jeong Han Lee
Sent: 15 February 2016 22:31
To: Mark Rivers; [email protected]
Cc: Jeong Han Lee
Subject: Re: Guide needed in order to work with the EPICS related Git repositories
Hi Mark,
Thank you for your workflow. It is the exactly what I am looking for!
And I should follow your comment in order to work with EPICS projects. Actually, I did them in one EPICS project without telling anyone what I would like to do, then I thought, I forgot to discuss this early with main developers and maintainers after I saw Ralph's comment.
Thank you again, I will understand your workflow first, then, I should do it them again with the proper procedure.
Han
On 02/15/2016 10:27 PM, Mark Rivers wrote:
Hi Han,
I'm not sure exactly what you would like. For the EPICS areaDetector
project there is a Github workflow guide here:
https://github.com/areaDetector/areaDetector/wiki/areaDetector-Git-Workflows
It is probably always a good idea to talk to the main developers
early. If you are doing a small patch then cloning and doing a pull
request back to the master branch is a typical workflow. But if you
are doing some major change then the developer will probably want to
create a branch for you and other developers to work on, and then you
do pull requests back to that branch.
-----Original Message----- From: [email protected]
Sent: Monday, February 15, 2016 2:47 PM To: [email protected]
Subject: Guide needed in order to work with the EPICS related Git
repositories
I would like to have a *nice* guide, which is always I could get in
here, in order to work with the EPICS related Git repositories at
github.com.
Is there any procedure which I should follow in order to do any pull
requests? Should it be better to talk plan to main developers or
maintainers before forking, doing pull requests, or both?
It looks like to add more features in some existent projects in near
future, but I don't have clear idea how to do this. Please guide me
to minimize any difficulties.
Thanks, Han
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA 94025
- RE: Guide needed in order to work with the EPICS related Git repositories ulrik.pedersen
- Guide needed in order to work with the EPICS related Git repositories Jeong Han Lee
- RE: Guide needed in order to work with the EPICS related Git repositories Mark Rivers
- Re: Guide needed in order to work with the EPICS related Git repositories Jeong Han Lee
Re: Problem compiling epicsOnce.cpp Eric Norum
<2016>
<2016>
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
