1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Problem compiling epicsOnce.cpp
To: EPICS tech-talk <[email protected]>
Date: Tue, 16 Feb 2016 14:07:17 -0800
The APEX project here is using R3.14.12.1 with EPICS_HOST_ARCH=linux-x86_64.   Everything up until now has been built with gcc-4.4.6.  I’m now trying to get the Galil motor support running.  This requires a more modern GCC to support the std=c++11 option.  I’ve installed gcc-4.9.3, but when I try to rebuild base I get:
remote/hpcs-sw/RHEL-6.x86_64/gcc/4.9.3/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include        ../../../src/libCom/cxxTemplates/epicsOnce.cpp
In file included from ../../../src/libCom/cxxTemplates/epicsOnce.cpp:29:0:
../../../src/libCom/cxxTemplates/epicsSingleton.h:37:5: error: 'size_t' does not name a type
     size_t _refCount;
../../../src/libCom/cxxTemplates/epicsSingleton.h: In constructor 'SingletonUntyped::SingletonUntyped()':
../../../src/libCom/cxxTemplates/epicsSingleton.h:162:23: error: class 'SingletonUntyped' does not have any field named '_refCount'
     _pInstance ( 0 ), _refCount ( 0 )
make[3]: *** [epicsOnce.o] Error 1
make[3]: Leaving directory `/remote/apex/software/epics/galil/base-3.14.12.1/src/libCom/O.linux-x86_64'
I’ve tried rebuilding just the Galil support module with gcc-4.9.3 and linking against the gcc-4.4.6-compiled version of base, but this core dumps when attempting to start an IOC.  Differences in the C++ runtime, I expect.
Suggestions?
Eric Norum
[email protected]
RE: Problem compiling epicsOnce.cpp Mark Rivers
Prev: RE: CSS PVManager/Diirt - Waveform of Characters to String Shroff, Kunal
Next: RE: Problem compiling epicsOnce.cpp Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Code-a-thon/Meeting/Training April 4-8 Eric Berryman
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
