Hello,
I want to use EPICS in my raspberry pi for beam position measurement. I will be using 4 16-bit ADC's for digitizing the output of the pickup electrodes. The ADC's support serial and parallel interfaces. Since the Pi does not have that many GPIOs, I will be using Serial Interface to get the data. I have a few questions regarding that. 1. The ADC (AD7622) supports 2MSPS. I wrote a python code to toggle a GPIO pin on a loop after some calculations and the maximum switching frequency I could observe in the Oscilloscope was 500kHz. Is that the maximum speed I can achieve using PI ? 2. The Pi has a dedicated SPI interface, so what is the maximum speed that can be achieved using it ? Another query I had, was regarding multicore processing capability of the Pi. 3. Is it possible to control individual cores, so that they can each perform one task that I assign to them, at their maximum capacity ? Any other suggestions you have regarding this setup would be very helpful. Thank You,
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
