1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: BOY Linking Container doesn't support OPI Search Path?
To: "Pearson, Matthew R." <[email protected]>
Date: Fri, 5 Feb 2016 15:25:01 +0000
> On Jan 29, 2016, at 11:54 AM, Pearson, Matthew R. <[email protected]> wrote:
> It would be nice if css had a -h option that lists all the command line options.
The option is “-help”, and it does include the -share_link info:
css -help
Command-line options:
  -help                                    : This help
  -version                                 : Version info
  -workspace_prompt                        : Always present workspace dialog, with preconfigured default
  -workspace_prompt /some/workspace        : Present workspace dialog with given default
  -consoleLog                              : Log all messages to the console
  -data /some/workspace                    : Select workspace on command-line, no prompt
  -share_link /path/to/folder=/CSS/Share   : Create links to shared folder
  -login                                   : Present login dialog (user, password)
  -u username                              : provide the default user in login dialog
  -p username                              : provide the password of default user in login dialog
  -set_password preference_name            : set a password preferences (will prompt for password or use previous -p {password} option)
-Kay
BOY Linking Container doesn't support OPI Search Path? Phil Atkin
Re: BOY Linking Container doesn't support OPI Search Path? Phil Atkin
Re: BOY Linking Container doesn't support OPI Search Path? Michael Davidsaver
Re: BOY Linking Container doesn't support OPI Search Path? Pearson, Matthew R.
Prev: asyn: drvInfo string vs. EPICS record name Phil Atkin
Next: RE: asyn: drvInfo string vs. EPICS record name Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: BOY Linking Container doesn't support OPI Search Path? Pearson, Matthew R.
Next: EPICS conference in Lund & EPICS-motor-wg meeting Torsten Bögershausen
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
