1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: epicsqt question
To: D Peter Siddons <[email protected]>, EPICS <[email protected]>
Date: Wed, 3 Feb 2016 23:31:17 +0000
Sorry Pete
One file didn't make it back into the repository. Should be good now. Sorry
Regards
Andrew
Sent: Thursday, 4 February 2016 03:37
To: Andrew Rhyder; EPICS
Subject: Re: epicsqt question
Hi Andrew,
   I had installed it from source some time ago. I just svn'd the trunk
again and tried to build it in Creator. Creator complains about XStretch
and YStretch being undeclared in class 'QEImage'. Any suggestions?
Pete.
On 02/02/2016 09:24 PM, Andrew Rhyder wrote:
> Hi Pete
> Yes there is a way. The bad news is it involves a code change. The good news I just did it.
> I've added a couple of properties (XStretch and YStretch) that you can use to stretch (or contract) the canvas used to present an image. So zoom, flip, rotate all do what they used to, but rather than then set the canvas to match the resultant image exactly, these properties will stretch the canvas (and the images drawn to it) as required. In your case you will can stretch the canvas vertically by, say, 10.0.
> The latest source on sourceforge has this change. Have you build epicsQt from source, or did you use a prebuilt version?
> Regards
> Andrew
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of D Peter Siddons
> Sent: Wednesday, 3 February 2016 7:05 AM
> To: EPICS
> Subject: epicsqt question
> Is anyone out there working with epicsqt? I am trying to display a set
> of 64 spectra (in Y) , each 4096 points (in X), as a QeImage. As you
> might expect, it looks long and narrow. I would like to stretch the
> pixels in the Y direction to make a more rectangular display. Is there a
> way to persuade QeImage to do this?
> Thanks,
> Pete.
D. Peter Siddons
Detector Development Group Leader
Bldg. 535B
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: [email protected]
Phone: (631) 344-2738
epicsqt question D Peter Siddons
RE: epicsqt question Andrew Rhyder
Re: epicsqt question D Peter Siddons
Prev: Job opening at LANSCE Faucett, John Allen
Next: Re: CSS Boy scripting, clear XY-Graph automatically Hinxx
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: epicsqt question D Peter Siddons
Next: CSS Boy scripting, clear XY-Graph automatically Christian Pauly
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
